Old 08-16-2008, 05:20 PM   #301
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Ok BigVinnie I wanna see what you know tell me where;
1) A boosted KA24DE (stock ECU) with 370cc injectors will hit zero vacuum in this map with a stock MAF sensor:
Old 08-16-2008, 06:15 PM   #302
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Well case in point the stock ECU never know's what size injectors it has, and a boosted KA24DE will hit 0 vacuum/boost transistion right about the ~64 LOAD section (I knew I should have wrote this down when I logged what a stock ECU boosted did on the map):
At this time between 1,400rpm and 3,000rpm (remember its interpolated to above and below cells) your are stuck in the ECU controlled part of the map which is commanding a 14.7 AFR (NOT GOOD) because by this time you are making boost allready.
To further put salt on the wound your timing is a 23* to 32* and this point in time depending on rpm ofcourse.
After you adjust your k value aka injector multipler and latency for the 370cc injectors so your shit runs right, you will access a different load at 0 vacuum/boost transition it will no longer be ~64 it will be different, it will actually move lower which means to the left of the map which means more timing and leaner AFR's, and the larger your injectors the smaller your k needs to be and you guessed it you move more to the left of the map, ofcourse this is all with only a change to injectors.
Old 08-16-2008, 06:58 PM   #303
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Originally Posted by UNISA JECS View Post
They go higher than that, again I really dont think you know to much about how things work in the ECU becasue again these timing values go higher than what you just said and they do so at much lower RPMS than 6,000rpm.
P>S> You need to see a ECU work in real time badly so you can eliminate some of yoru questions or I can see this could go on and on and I am no expert by any means but I know how to tune my own ECU.
The way the ECU calculate all this shit is comlpex, timing, fueling are all based on LOAD/TP (Theoritical Pulsewidth) without being able to see any of this stuff you are gonna be lost. Like your SAFC, if you knew truely or had any expereince in tunning an ECU you would frown down upon a SAFC, really.
It's just that in any real circumstances my memory just sucks.... I do get the basic fundamentals but then again pounding a bottle of liquor almost every other night and killing brain cells is more damaging to me retaining information.
But in any case I have the fundamentals down and I get what your saying....
An SAFC does suck I never once said it is superior than any type of rom tune , or standalone but in any case when it comes to natually aspirated tuning and basic changes to fuel an safc works fine, especially since there isn't to much wrong with the stock tune to begin with...
The only real trick to making the numbers I did on the dyno was just by changing the MAF which I believe under load changes the K value a bit....
BigVinnie is offline   Reply With Quote
Old 08-16-2008, 07:06 PM   #304
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I agree with that 100% for a NA engine you can manipulate/tweak the system in a favorable manner if you know what your doing, and you do appear to know the SAFC. An adjustable fuel pressure regulator woudl work well to, to lower the base fuel pressure a tad and a wide band ofcourse.
Old 08-16-2008, 07:15 PM   #305
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
It actually changes the LOAD/TP you are correct, I haven't documented or actually watched what happend in real time because I am still using a stock S13 MAF but I have a N60 and N62 MAF that I will hook up and see which way the load/tp moves, my logic tells me though that it will move to the left on the load scales.
My reason for thinkng this is because generally the bigger the MAF the smaller the value for a given MAF voltage, since all this values are multipled to come up with the final LOAD/TP, smaller values = smaller total k = smaller LOAD/TP
Old 08-18-2008, 12:00 PM   #306
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
Jason, thanks for the help, E-mance is great.
your Rom Tune still runs perfect. fully built head, running 22lbs, flawless, 11.8-12.0 afr, killed a z06 with some bolt ons last night Your a great person to work with, and your customer service is awesome. Any other company would just put you on hold for 20 hours and then blow u off.
Chrischeezer is offline   Reply With Quote
Old 10-05-2008, 12:11 PM   #307
nemo6686
nemo6686 is an unknown quantity at this point
I just got a sr20det tune from him. It runs so rich you can only drive it for 15 mins. Before it burn the plugs. I have pm him several times about the issues. He said that he sent me a new tune. But that was 2 weeks ago. He also won't give me a tracking number. I should have gone with enthaply tune ecu
nemo6686 is offline   Reply With Quote
Old 12-11-2008, 03:42 PM   #308
s13.5guy
s13.5guy's Avatar
s13.5guy is an unknown quantity at this point
I just ordered from Jason to support my KA24de-t. Hopefully things work out
s13.5guy is offline   Reply With Quote
Old 12-12-2008, 10:03 AM   #309
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
i have a stock ka24e what can you do for me?
redline racer510 is offline   Reply With Quote
Old 12-12-2008, 02:18 PM   #310
480sx
480sx is an unknown quantity at this point
www.ka-t.org :: View topic - Did E-mance go out of business
480sx is offline   Reply With Quote
Old 04-14-2009, 12:13 PM   #311
Yuda
Yuda is an unknown quantity at this point
got my emance ecu back. works great no problems. will do business with him again when i upgrade turbo.
Yuda is offline   Reply With Quote
Old 04-16-2009, 06:04 PM   #312
carcrossy
carcrossy is an unknown quantity at this point
Jason is a pretty shady character. He sold me a consult cable with supposedly registered unique software. Turns out it is obd scan tech which is completely free. obd scan tech guy never heard of jason. Jason acturally edited the software so that "emance" shows up as part of the name of the software when you log on. ie "emance obd scan tech"
carcrossy is offline   Reply With Quote
Old 10-01-2009, 01:54 AM   #313
tpetrucci33
tpetrucci33's Avatar
tpetrucci33 is a well-known jackass
Awesome experience with Jason at E-Mance. Had some little bugs with my chip but got that solved within hours. He even gave me a ride in his 700WHP+ s14. Mannnnnnnnnnnnnnnnnnnnnnnn!!!!!! Talk about a sleeper. And I give the new Gizmo launch control an A++++++. Will be buying one in the near future.
tpetrucci33 is offline   Reply With Quote
Old 10-01-2009, 08:50 AM   #314
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
sounds like this guy may finally be getting his stuff together.
SuicidnS13 is offline   Reply With Quote
Old 10-01-2009, 10:12 PM   #315
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
so like anyone have any vids on this?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 10-05-2009, 02:16 AM   #316
tpetrucci33
Yea he's a real cool guy. I'll try and get a vid up here shortly.
Old 10-06-2009, 11:16 AM   #317
blackoutt
blackoutt's Avatar
blackoutt is an unknown quantity at this point
Thinking about goin emance. Sounds like the best bang for your buck.
blackoutt is offline   Reply With Quote
Old 10-31-2009, 08:11 PM   #318
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
I know of two cases of fried ecus after tuning with emance... Mine was one of them. Burnt a trace in the ecu fried a diode... I drove it for a little while though maybe 60 miles.
Some people have had luck though.
om3ga is offline   Reply With Quote
Old 11-01-2009, 11:42 AM   #319
nosajton
nosajton is on a distinguished road
burnt diode is usually a result of incorrect wiring of MAF or short in ignition wiring somewhere. a diode isnt going to burn out on its own.. only will when you swap positive and negative wires somewhere or your wiring gets shorted out..
i fix these types of ecu's daily from customers who install maf incorrectly.
04 G35, Kinetix Plenum, Borla Ext, JWT Intake, custom ETG ECU Reflash.
nosajton is offline   Reply With Quote
Old 02-14-2010, 03:51 PM   #320
preston240sx
preston240sx is an unknown quantity at this point
i retract any statement i made jason is an awesome guy will do all mu business with even made a personal try to my house and fixed any problems i had
preston240sx is offline   Reply With Quote
Old 02-15-2010, 01:16 AM   #321
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
my car ran fine for over a year with this tune.
maybe he only likes certain ppl
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 02-15-2010, 01:50 AM   #322
z2roll4life7
z2roll4life7's Avatar
z2roll4life7 is an unknown quantity at this point
Ive Had His Tune For Like 6 months Now Only Thing Changed was
I Bought a z32 maf From him and he gave me the Retune To run it For Free
also Jason i talked you awhile ago about a retune for my new 2871r well my head is getting built and ill be running Cams and i want to run e-85 my car should be ready at the end of the month ill hit u up man
z2roll4life7 is offline   Reply With Quote
Old 02-18-2010, 02:48 AM   #323
nosajton
Edit, found solution
Old 02-18-2010, 08:08 AM   #324
smelly240
smelly240's Avatar
if its backfiring out the intake - its almost certainly the dist/cas needing someone that knows what they're doing to adjust it.
I'm not sticking up for someone with obviously questionable ethics - but that is something I've dealt with before - when customers or their "friends" set their own timing - they assure me its right and then when i unplug the tps they look at me like im an alien. Its something thats probably a issue since he does mail order stuff.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 02-20-2010, 10:07 PM   #325
preston240sx
My bad
yeah sorry jason was my bad... ur a stand up guy thx for all the help sorry for any negitivity i was just mad at my car
Old 02-20-2010, 11:24 PM   #326
nosajton
glad we got it running great, enjoy
Old 03-13-2010, 08:09 AM   #327
street240
street240's Avatar
street240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nice
I cant beleive this thread is still going all these years later
The Gallo 24 would be a better motor for my skyline...But I am waiting on the swap dvd...
street240 is offline   Reply With Quote
Old 03-13-2010, 08:29 AM   #328
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
...which reminds me, I'm running nosajton's tune. It's been a few months. Might be contacting you soon for retune chips. I'm on the edge of going bigger turbo/injectors.
Good customer service and nice prices. thanks.
VNG704 is offline   Reply With Quote
Old 03-24-2010, 11:43 AM   #329
NolimitZ32
NolimitZ32 is an unknown quantity at this point
Hey I've been a member here for a while but never posted, I am a legit member on NICO so if anyone doubts anything about me you can check out my history there (to ensure that this is not a troll post). I am currently in the process of getting a Z32 custom tune chip from Jason, I will be installing it myself in the ECU and will give you my impressions when everything is set and running.
NolimitZ32 is offline   Reply With Quote
Old 04-04-2010, 10:20 PM   #330
aznevoviii
aznevoviii's Avatar
aznevoviii is a jewel in the roughaznevoviii is a jewel in the roughaznevoviii is a jewel in the roughaznevoviii is a jewel in the roughaznevoviii is a jewel in the roughaznevoviii is a jewel in the roughaznevoviii is a jewel in the rough
Send a message via AIM to aznevoviii Send a message via MSN to aznevoviii
so i guess after all these years, Jason finally putting stuff together real nicely!!!
i am now drolling over your auction on ebay, can u do better on pricing? (like zilvia.net special)...
aznevoviii is offline   Reply With Quote
