Old 08-26-2008, 07:15 PM   #1
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
Originally Posted by zylvia213 View Post
Yea ill give it a try before taking the manifold off. Now does anyone know the torque specs for the bolts that connect the intake manifold to the head???
2 step process. all bolts to 8ft-lbs, then 20 ft-lbs. of course starting in the center.
as far as the gasket, there are plastic "thermal" gaskets that supposedly reduce heat transfer and also serve to increase air volume... circuit sports i believe makes them. they are also re-usable which is why i bought one.
aNskY is offline   Reply With Quote
Old 08-26-2008, 10:28 PM   #2
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
fsm manual has it as one step 13-15 ft lbs
n240sxfnatic is offline   Reply With Quote
Old 08-28-2008, 04:57 AM   #3
aNskY
uhhhhh, no... where do you think i got that info?
Old 08-28-2008, 12:20 PM   #4
n240sxfnatic
ummm I know where I got it, the fsm in front of me, its an s14 sr but torque spec are said to be the same
