Old 04-09-2003, 04:28 PM   #1
Red
Red's Avatar
Red is an unknown quantity at this point
What is the differance between Shocks & Struts?
I need to know all the difference's between shocks and struts.... What makes one better then the other... The best thing would be a web site's where I can read about them.
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 04-09-2003, 05:55 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Re: What is the differance between Shocks & Struts?
One isn't necessarily better than the other. Both are dampeners. A strut happens to be a shock that makes up part of the suspension linkage, that's all. It usually replaces the job that the upper tie rod does.
AceInHole is offline   Reply With Quote
Old 04-09-2003, 08:36 PM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
FWIW, our 240sxs have Struts up front, and Shocks out back. Uhhh... yeah.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 04-09-2003, 09:55 PM   #4
AKADriver
AKADriver's Avatar
here's a post I made last week:
A "strut" in an automotive suspension is a vertical link that supports and locates the spindle or upright, and out of necessity of being vertical (in the direction of suspension motion) always includes the damper and usually includes the spring perch. This means that a strut mounts SOLIDLY to the spindle/upright at the bottom.
The 240SX front suspension is a standard McPherson strut type suspension, with the exception of the tension rods, which are a nice addition, when they work.
The 240SX rear suspension is a multi-link design that does not incorporate struts. The dampers are mounted via a bushing to the uprights, they do not serve to locate and support the uprights, and therefore are not struts. The damper assemblies DO include the spring perches, which leads most people to incorrectly call them struts, and most people know what you're talking about if you say "rear struts" to refer to the rear damper assemblies.
Also note my use of the word "damper" instead of "shock absorber". "Shock absorber" is an unfortunate misnomer. The springs absorb shocks, the dampers serve to damp the motion of the springs (hence "dampers").
Old 04-09-2003, 11:43 PM   #5
Halz
Halz's Avatar
Halz is an unknown quantity at this point
Bicycles have shocks.
Cars have struts.
Defined...
a 'shock' is - "A shock absorber."
a 'strut' is - "Any part of a machine or structure, of which the principal function is to hold things apart; a brace subjected to compressive stress; -- the opposite of stay, and tie."
Halz is offline   Reply With Quote
