![]() Join Date: May 2002
wastegate bar?
ok... i just found out the wastegate that i had gotten was a .3 bar.... that means 4.5 psi correct??
and if i dont have a manual boost controller then i will only be pushing 4.5 psi... but if i did can i push more? or will i have to change the spring? |
![]() Join Date: Feb 2002
Yeah, you will be set at 4.35psi with a .3 bar spring (14.5 *.3 = 4.35). If you want to push more boost, you can pick up a boost controller (manuel ones for like $60.00), or just buy another spring with a higher boost rating. I would suggest buying another spring because it's cheaper and will prevent boost spikes a lot better than boost controllers (at least the manuel ones).
"Pure adrenaline attached to a license plate. Isn't it time to experience one yourself?" -Dan Gurney Turbo for Sale |
YOU CAN ONLY INCREAE BOOST TO A POINT. THE SPRING WILL START CAUSING BOOST SPIKES CUZ OF ITS LOW SETTING TO BEGIN WITH. BETTER OFF GETTING A HIGER RATED SPRING. IF YOU WANNA GO OVER 10 PSI GET A STIFFER SPRING.
240sx s-13 TURBO weekend v-8 killer 90 Talon TSI WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY. |
![]() Join Date: Mar 2002
I've run 15psi on my .3bar Tial wastegate spring no problem for a long time. I don't see how it matters...since the boost controller applies boost pressure to the top of the wastegate to assist its closing. I mean, it isn't like the spring has to do any additional work...the boost on top of the wastegate does.
Dennis |
