Old 09-11-2008, 09:16 PM   #1
deuceforty
deuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of light
How to install arias piston snap rings?
these are really weird... they loop around like a keychain? cant figure out how to put them on
TWO TONE COUPE FS NC
deuceforty is offline   Reply With Quote
Old 09-11-2008, 10:28 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
best bet is to call piston company and talk to tech guy...
Not saying someone here doesn't know, but if you follow wrong direction your buying new rings... dont want that!
gl brudda
sillyvia13 is offline   Reply With Quote
Old 09-12-2008, 07:21 AM   #3
deuceforty
is case anyone else has this problem and finds this thread from a search, these are the rings
they are called spiral retaining rings
you are supposed to use a small screwdriver to walk them in or something
Old 09-12-2008, 02:15 PM   #4
goldee240
goldee240's Avatar
goldee240 is on the path to ruingoldee240 is on the path to ruin
agree just call and ask
good luck with build
goldee240 is offline   Reply With Quote
Old 06-02-2009, 02:25 AM   #5
kamerononfire
kamerononfire is a well-known jackass
i know i'm bringing back an old thread.. but i'm facing the same problem, having a very difficult time installing the retaining ring. has anyone done it before, and can offer some advice?
kamerononfire is offline   Reply With Quote
Old 06-02-2009, 10:48 AM   #6
deuceforty
they are a pain in the ass to do.
you use a small precision screwdrive to walk them around until they pop in.
Old 06-02-2009, 12:23 PM   #7
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
I stretched them out just a little then, like said above, get them started and follow around pushing in with a flat head.
S14 Build
DRFT180 is offline   Reply With Quote
Old 06-02-2009, 05:25 PM   #8
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
I used the all the time at work Duece, here goes:
1. Secure piston in something so it doesn't move.
2. Bend out the side you are going to insert into the groove a little.
3. Use either a scribe or a pointed punch to "walk it" all the way around slowly.
4. BAM! One down three to go.
OR
You could come down and I can do it for you on saturday.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 06-10-2009, 09:27 PM   #9
deuceforty
OR
check the thread date got this done a while ago.
thanks for the offer though!! <3
