![]() hey my check engine light is on and it says its a knock sensor and it also says iacv-aac...
is it bad if i drive it around like that. the car runs smooth but iam afraid it will die on me. |
LAID OUT
![]() Join Date: Mar 2004
IACV I don't know the solution, you may have a short or the unit itself might be bad/gummed up/etc. |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
I don't think the ecu is smart enough to detect a mechanical failure in the iacv (gummed up, etc...). It almost certainly has an electrical problem. Not onlyu that, but I have actually taken an iacv apart and I see no reasonable way that the iacv could get clogged. To start make sure the connection for the sub-harness that goes under the intake mani is clean and stick a pick or small screwdriver in there and crimp down the female pins a bit more. Also make sure the iacv connector itself is actually plugged in, clean and tight.
#4 | |
