![]() Join Date: Feb 2002
Just an idea to start my turbo setup.
I dont know if this would work. But its an idea
I was thinking of upgrading my fuel system 1st an in Walbro/300TT fuel pump. New fuel rail with 720cc injectors Cobra MAF and a JWT ecu to make it all work. You think this would run right on a stock 95 240sx? And would I be able to boost it later without a reprogram? Maby I should e-mail JWT and ask ehh?
http://www.cardomain.com/memberpage/509537 http://www.imagestation.com/album/?id=4287415487 http://www.zilvia.net/f/showthread.php?t=21036 |
#2 | |
I hate you too...
![]() Join Date: Jul 2001
Re: Just an idea to start my turbo setup.
The JWT program uses 72# injectors. Also, the idle will suffer severly with those injectors. Do a search before I decide to stop bieng nice. 72# injectors will handle 350-500rwhp on our cars, and you're probably never going to make that. I'll be running 50# injectors, and most other people run 50's too. 350-360rwhp from the 50# injectors... so 72# are like the final step in turbo fuel. Search for the ammount of boost you want to run. You'll get hits on 4, 7, 10, 12, and 15 psi for the KA. -Jeff
Whatup? |
Yeah I know the 720-740cc (whatever) will run that much HP.
Thats the Idea. Do it once do it right. And this is not for a turbo setup yet. I was wondering how my car would run... ohh without a turbo. I'm not done planning my turbo out yet. But if I get the fuel system all upgraded. then when I get to it I can slap the rest in and be on my way to happy boosting... (Cmon GS increase)
#4 | |
I hate you too...
The idle will be terrible since huge injectors can't flow the little bit of fuel that you need at idle. Also, the ecu program will flood your car with fuel at higher RPM.. cuz it's based off a fuel map, not a fuel demand. You'll get 14mpg, foul plugs in a couple weeks, and have nasty emissions. At least wait until you get a turbo to put it on.. and even then.. you probably won't need it. -Jeff
Whatup? |
![]() Join Date: May 2002
talk to Asad from www.Freshalloy.com hes been running a turbo fuel setup without the turbo for a while...
#6 | |
I hate you too...
When you go with the 72# injectors, you have to bump up the fuel pressure to 4bar and run a Nismo regulator. Couple that with an injector that's pulse width is too large to idle right, and it's a recipe for a bad time, because it's just too much fuel man. -Jeff
Whatup? |
So I guess my idea it not totaly invalid. I just need to rethink my 1st step and go a bit smaller.
Thanks for info.
#9 | |
Autox Technician
![]() Join Date: Dec 2001
#10 | |
![]() Join Date: Jan 2002
240SXONE www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx ![]() ![]() |
