Old 09-22-2008, 10:32 PM   #22
mrmephistopheles
mrmephistopheles's Avatar
Originally Posted by JRas
I thought 4.63 gears would be shorter, therefore the engine revs would climb more quickly?
I'm a bit confused please explain how this stuff works, Please
Thanks
Think of it like this - Let's say we're working with a button and a light, and 3:1 and 4:1 ratios.
3:1
Press the button 3 times, and the button lights up for one second.
Press the button 180 times and you've got light for a minute.
4:1
Press the button 4 times, and the button lights up for one second.
Press the button 240 times and you've got light for a minute.
You can see there's a difference of sixty button pushes between the ratios. Consider that as a difference in how much an engine has to work.
Let's change the button presses to revs/min (rpm) and increase by a factor of 10.
1800rpm for a minute will get you a mile, or 2400 rpm for a minute will get you a mile.
Seeing the difference here?
4.36 or 4.6 gearing makes the engine work harder throughout the range of speeds.
Off-the-cuff example (not accurate by any means - just an example).
60mph
4.08:1 (stock) = 3500rpm
4.36:1 (some Silvias) = 3850rpm
4.6x:1 (something) = 4200 rpm
3.69:1 (S15 SpecR) = 3200rpm
That's messing only with final drive ratio, not tire/wheel sizing or transmission gearing.
As you can see, the engine has to spin more, work harder and burn more gas to do the same amount of work.
Originally Posted by PHLIP
