Sway bars what's good?
Hey guys just recently have been looking into sway bars. Can you guys just give me a run down of some good ones that any of you have for the S13, I'm not looking to spend a huge amount of money i saw a set for like 220 on Enjukuracing.
Any other feedback would be greatly appreciated. |
thanks i'm going to look into the whiteline ones.
#6 | |
Autox Technician
![]() Join Date: Dec 2001
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
I've heard the stock endlinks with the whiteline bars work better, but I'm not going to test it until I can get some new poly bushings for the stock endlinks.
#8 | |
WOW addicted
I got the Suspension Techniques after seeing how crappy the Whiteline endlinks were. I didn't want to use the stock links with the WL bars since I heard you can really only use the middle setting on the rear without really tweaking the bushings. The adjustablity would be nice, but I'd rather have a "proper" non-adjustable setup. I had to use some washers and creativity to get the brackets to fit right though, and the rear bar taps my HKS Sport cat-back when shifting. If I was anything but a penny pinching tightwad I'd say spring for the Cuscos. They are 28mm/18mm instead of 27mm/20.6mm so they will not be as oversteery as the ST bars, which is good since combined with HA's the car is a bit spooky at times. On a strange side note, the ride was actually SMOOTHER with the new bars.
sorry to jack your post... but for an s14... would you need the D link for the Suspension Techniques.... how would you rate these compaired to w/l's.... im about to order some tomorrow... need some help... how would you think is the better route?
![]() Join Date: Apr 2002
If you plan on deviating from the stock spring rates, Whiteline's adjustable bars make the most sense.
As far as I know, all of the antiroll bars on the market are 'tuned' to the stock spring rates. Changing the spring rates would change the roll rate, at which point, a non-adjustable bar could hinder the car's overall performance. The 'problem' with Whiteline's endlinks was that people were not installing the bar properly. See this discussion on Whiteline's techboard http://autos.groups.yahoo.com/group/...e/message/2401 Installing and tuning any suspension component should be done with the car are ride height (even struts/coilovers, to an extent.. the strut housing on the front must be 'resting' on the bolts. Granted, this would be taken care of shortly after the inital drive..) Polyurethane bushings must not be 'tight'. The bushing is not at all like rubber. If a bushing is tight, is will bind, thus not allowing the bar to be very effective. |
good and cost effective, go with ST or whiteline..
if you have a lot of money to shell out, there is cusco, and nismo.. a good bar that cannot be attained here. Largus. ST should be sufficient enough in my opinion. |
#14 |
Just how necessary are sway bars anyway? I am just stating to tune my car, still has full stock suspension. My first upgrades are going to be new bushings and control arms up front, and then I'm going to get new shocks. probably kyb agx, and then some tein type S or whiteline springs.
I really didn't plan too far beyond that. would aftermarket sway bars significantly help me? |
#15 |
IMHO, the sways are one of the best "bang for the buck" improvements on almost any car, with no downsides. Unless you have a hicas car (bigger stock bars), these should be one of the first suspension upgrades....side by side, I beleive your car would handle better with new bar vs. stiffer springs. If you do both, you'll be amazed how flat your cars stays. remember tires are very important as well, as only they contact the road and ****** tires (flexible sidewall) on stiff suspension will fold, screech, and slide in all the corners
'93 Fastback LE - Wrecked '91 Fastback HICAS and LSD - Sold '93 Fastback SE - Current |
#16 |
I have a friend running whitelines sways....
one with a 97 ka, whose bushings gave out..... on the other hand, 95 s14 sr (muah) had no problems with the sway bar or the bushings......everything is just fine..... btw, my friend didn't install his wrong......he did his install and my install the same way.....so i tend to believe that whiteline bushings are not the strongest but the product is awesome....we both have it on full stiff.......he runs spring/shock combo (don't remember what combo).....i run TEIN FLEX..... I say whiteline adjustables, if the bushings go out, you can replace them with stock ones or buy the napa special... RINKU |
#17 |
WOW addicted
Swaybars are indeed THE best bang for the buck suspension mod. period.
Sway bars are for controling sway. Springs are for controlling bump. if your springs are stiff enough to control sway, then they are too stiff. I'll be picking up a set of Whiteline sways in a month or so. For the record.. JIC USA uses ST sways on their project s13.
#18 | |
![]() That said, I feel fine running my stock HICAS/JDM rear swaybar... for S13, that is. If you pull the HICAS rear sway out (or JDM rear sway) you'll find it's substantially bigger than the USDM non-hicas base model sway. ![]()
Instagram: @SX180HKG |
#20 |
IIRC, the HICAS rear is 21 mm, right up there with the aftermarket units
#21 | |
#22 |
WOW addicted
No.. Hard springs cause erradic bump-steer. thats why it's call "BUMP" steer.. and not "Roll" steer...
Hard springs are a Crutch for having something else not tuned properly on your car, and can actually cause you to have much less traction b/c the wheel and chassis reacts so violently to sharp changes in pavement conditions. ESPECIALLY if you don't have much chassis bracing to force the spring and damper to absord the shock.. Having lighter springs (8front 6 rear IS light) and a stiffer sway bar will allow for the tires to be connected to the road better, and will increase speeds because your Transitions will happen faster because your car isn't rolling as much. When your car is mid corner, and body roll is locked by the sway bar, and you hit a bump, you still have travel in the suspension to absorb the bump without upsetting the cars balance. If you have Hard spring, and light bars, then the sway is being controlled by the spring. If you hit a bump with all that roll pressure sitting on the spring mid corner with the car balanced, suddenly you upset the cars traction points. If your springs can't absorb the bump because they are busy controlling roll, the CHASSIS has to take the bump. This will make the car more unpredictable, and ultimately lead to slower lap times. Balance, and Predictability are PARAMOUNT. If you can't run consistant lap times, or consistantly improve b/c something in your setup changes every lap, you don't get any better, and SURE aren't gonna win. BTW - If you get the 240 to do some "Dog Pi$sing" 3 legged action, just means that you had all the traction being placed on the front opposite corner. The car isn't setup properly. My bet is your springs are too soft, and allowing for too much weight transfer to the front under braking. That combined with chassis flex while turning hard. (you probably like to trail brake?) will cause the rear tire to hang from your sway bar. Overall reducing your total possible traction
![]() ![]() Last edited by sykikchimp; 04-18-2003 at 09:11 AM.. |
#23 | |
from Canada, eh!
![]() Join Date: Sep 2001
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#24 |
![]() Join Date: Aug 2001
err really?
is anyone else in agreement that most of the aftermarket sways are solid? i have no experience with them, but i'm pretty sure that would be stupid for a few reasons.
The sways would weigh a ton. You can make stiffer bars that are hollow with less material while saving weight. or i could be talking straight outa my ass... are there any civil engineers in here?> they'd know for sure.
__________ 96 s14 300zx lsd zeal b2's |
#25 | |
