Old 10-05-2008, 03:42 PM   #3
Pho Man
Pho Man's Avatar
Pho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymore
Send a message via AIM to Pho Man
Originally Posted by inxdifference View Post
sounds to me like you plugged it in wrong. one of the plugs (the big one) goes in the middle. but the one to the left and right are both the same size so switch thoes around and your tach should work correctly. . . oh you also have to splice the yellow red wire to make your rpms work
Your talking about the yellow wire with the red stripe? and what do you mean splice it?
Also I did end up reversing the black plug on the gas side and the white plug on the temp side. That is fixed Plugged everything in and RPM's are working blipped the throttle and it's working without splicing any wires.
Thank you for the help.
Pho Man is offline   Reply With Quote
