Old 10-07-2008, 10:26 PM   #1
krisdeezy
krisdeezy's Avatar
krisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant future
Send a message via AIM to krisdeezy
26mm z32 front calipers
so i bought some calipers on here and they diddnt come with hardware and i found a great deal of all the hardware for a 300zx tt and that's the 30mm ? so will the hardware fit on the 26, such as retaining pins and etc. ? i looked up a site of the whole set it seems to say "fits both 30mm and 26mm" ??
krisdeezy is offline   Reply With Quote
Old 10-07-2008, 10:36 PM   #2
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
pretty sure they r the same..
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 10-07-2008, 10:51 PM   #3
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
I have a pair of both sizes and the hardware is exactly the same.
MrMcgarrett is offline   Reply With Quote
Old 10-08-2008, 08:17 AM   #4
cdlong
the pins that the pads hang on should be different since they span the opening (which is different between the 26 and 30mm calipers) and they don't have any extra length on my 26's. they would technically work, but they should have different part numbers. that site may have just been simplifying their stock too much. everything else should work though.
you could try cutting them shorter and drilling a new hole in the longer pins.
cdlong is offline   Reply With Quote
Old 10-08-2008, 02:01 PM   #5
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
from the dealership.. the 26mm is cheaper.
I'm not 100% sure the pins are the same length.
I dont think they are unless they sit in more on the 30mm calipers.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-08-2008, 02:46 PM   #6
projectRDM
projectRDM's Avatar
The dealer superceded the 26mm pins with the longer 30mms, either set will work. Everything else is the exact same.
FORMERLY R240NA
Old 10-08-2008, 10:16 PM   #7
krisdeezy
krisdeezy's Avatar
cool. thanks alot you guys for the help !!!
