![]() Join Date: Apr 2008
![]() ![]() Feedback Score: 2 reviews
Need help with Apexi Power FC. Defective maybe?
So my Power FC just came in yesterday after a looong week. Only problem is when I plug it in, nothing happens. Commander doesnt come on and car wont start. I checked and re-checked to make sure it was plugged in correctly. Ive checked and re-checked the part numbers on both my stock ecu and Power FC. When I plug in my stock ecu everything works fine. Car starts right up and drives with no problems.
My ecu is an NA code. Part# 23710 80F00 The Power FC unit I have is 414AN016 Power FC 96-99 SR20DET Silvia S14(After Minor Change) My car is a 95 s14 with a later model SR20DET What the hell can be wrong. Here is a pic of my stock ecu: ![]() |
![]() Join Date: Jun 2003
Trader Rating: (130)
i'd check the apexi website. they have a large faq section for power fc.
A'PEXi U.S.A. - Support |
Turn off your boost control assuming you do not have the Apexi boost control kit. Your car won't start if it is on and you do not have it.
Use google search for Pauls R33 Apexi Power FC FAQ |
#8 | |
If someone knows where I can get a complete wiring diagram for my ecu, please let me know. Thanks. I found one diagram but it doesnt list what all the pins are for, just a few. Thanks again. |
![]() Join Date: Oct 2002
Apexi PowerFC FAQ
Taken from the FAQ "My car won't start when I plug in the PowerFC, but the stock ecu works fine First when dealing with a new PowerFC install and the car does not start there are a few basics to check; Check the PowerFC to car loom connector Check the warning lights on the dash, do they come up? On the hand controller, goto ETC, SENSOR SW CHECK, are any sensors highlighted in black? (Shouldn't be) Make sure you disable the Boost Control Kit if you aren't using it Make sure you have the right airflow meter selected (if you have a non standard one) Make sure you have correct injector settings (if you have non standard ones) Check all fuses Listen for clicking relays Check for burning smells near the ECU and or inside the ECU Inspect the ECU itself for physical damage or burn marks (open it up) " I'd check the bold ones, since your hand controller isn't powering the rest are hard to do... I wouldn't open up the unit unless you know what you are doing, it may sound silly, but smell the PFC ECU, if you are at all familiar with the smell of burnt electronics, you will know what you are checking for. Hopefully it is a fuse or ground issue. Good luck.
Marc - Yokohama, Japan ![]() |
RedStage,
Thank you for the help. I dont know how I missed this part of that FAQ. I'll try those and see what happens. I am familiar with that smell, unfortunately...lol. Thanks again. I'll keep you guys posted on my findings. |
Ok so there is nothing wrong with my Power FC. I found a list of the pins on the ecu connector and found that there are 3 ECCS wires. One for ground, one for back up power and one for power. I found only the backup wire had constant 12v. The other power wire had nothing. So I jumped this pin and voila, Power FC and Commader came to life. car started up and everything.
I still have a problem. My Power FC wont save any changes. The only changes it saved were changes to the injector values. This is when I had constant power to both ECCS wires. I ran switched 12v to the eccs power wire since the Commander wouldnt turn off when I had constant 12v running to both wires. Now it wont save any changes to the maps, rev idle, nothing. Is anyone familiar with these ECCS wires? What is ECCS? |
#14 |
Sorry for pic up this old thread,
but i need the pinouts for the 23710 80F00 NA ECU Can someone help me? There's nothing the same like the europen s14a it's an 1998 Kouki S14 imported from japan. Last edited by GotMilk?; 06-23-2009 at 10:34 AM.. |
