Old 10-13-2008, 11:59 AM   #1
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
To you Power FC Experts. Check this please.
Ok so I checked my sensors and I have solid dots on the following sensors:
IGN solid black
STR solid black
ECC sold black
F/P solid black
O2H solid black
VTC will blink once when I tap on the gas but doesnt stay on.
This is what I have at idle:
InjDuty 1.7%
Ign Tmng 30 deg at idle
AirFlow 1270mV 1290mV
EngRev 1100-1153 rpm
Knock 2 - 5 at idle, went as high as 30 when I drove around.
Wtr Temp 70
Boost ------ mmHg <--- I guess thats because I dont have the boost control kit? I have my own boost controller though.
Im taking this thing to get tuned as soon as I get my 2871r, for now, I'd
like to know what is going on with my motor.
Anything I should be concerned with or any advise??
Erjay1 is offline   Reply With Quote
Old 10-13-2008, 12:01 PM   #2
johngriff
johngriff's Avatar
Take it to steve.
Shadowerks
[email protected]
Old 10-13-2008, 12:05 PM   #3
TTrx7Pete
TTrx7Pete's Avatar
TTrx7Pete is making a name for him/her selfTTrx7Pete is making a name for him/her selfTTrx7Pete is making a name for him/her self
IGN solid black
STR solid black
ECC sold black
F/P solid black
O2H solid black
InjDuty 1.7%
Wtr Temp 70
When you do a sensor check in the ETC menu, a solid circle means that the sensor is operational or switched "on". A hollow circle means it is switched off. If the sensor is HIGHLIGHTED, it is malfunctioning and not sending a signal to the ECU.
The knock is normal. The knock sensor measures all engine sounds. The reason you are not reading boost is because you do not have a factory boost sensor. So that sensor reads nil.
Recommend you still go get it tuned by someone who knows what they are doing. PFC is dangerous thing in the hands of a n00b.
1993 AW Mazda RX-7
1997 Nissan Silvia
TTrx7Pete is offline   Reply With Quote
Old 10-13-2008, 12:06 PM   #4
Erjay1
Erjay1's Avatar
I will. After I get all my stuff. Still needs cams and my turbo before I'll pay all that cash for a tune. Thanks though.
Old 10-13-2008, 12:15 PM   #5
johngriff
johngriff's Avatar
For a stock SR, he shouldnt be seeing knock like that at idle. Something is really wrong. Stock boost and 30? 15% knock? No good. There is a problem there and it needs to be looked at now. For a more modified car, I would expect the knock to be higher because of a louder valvetrain or large vibrating turbo, but not like this.
[email protected]
Old 10-13-2008, 12:47 PM   #6
TTrx7Pete
TTrx7Pete's Avatar
Its entirely possible that nothing is wrong and it is really the timing causing the issue. I say get it tuned. I wouldn't drive on the car or be running it without having it tuned. He needs at least a base map to get started.
I've seen knock sensors jump all over the place without the engine actually knocking, lots of things can cause the issue, such as a bad knock sensor...
1993 AW Mazda RX-7
1997 Nissan Silvia
Old 10-13-2008, 12:56 PM   #7
johngriff
johngriff's Avatar
You just post to waste time?
Obviously, but for the sake of the "internet" you have to assume everything here is a sample test in a vacuum on a perfectly set up automobile. Once you take that factor away, you have to have someone look at the car in person.
Taking that into account, that is why I provided the first link for him to take the car to a tuner, because there is no quantifiable way to make an accurate diagnosis of anything simply through the internet.
I swear some people want argue for the sake of arguing.
[email protected]
Old 10-13-2008, 01:18 PM   #8
Erjay1
Erjay1's Avatar
Its cool guys. Im gonna take it to Steve once I get all my parts installed. I just thought maybe someone could give me an idea of whats going on by simply looking at those numbers. Thanks guys.
Old 10-13-2008, 01:24 PM   #9
nzmoman
nzmoman's Avatar
nzmoman is an unknown quantity at this point
If you think there is something potentially wrong I would actually take the car to whomever is tuning it first. No need in going through installing more stuff if something is wrong and you are still going to have to get the car looked at. I am sure you can get a base set up done for fairly cheap and then go get crazy later, but either way I would imagine that you will visit a tuner more than once, assuming you are going to be as meticulous as some people are about break in and retuning.
nzmoman is offline   Reply With Quote
Old 10-13-2008, 01:29 PM   #10
Erjay1
Erjay1's Avatar
Yup, I just emailed Steve at Shadowerks to see about a base map before I get a full blown tune.
Old 10-13-2008, 06:48 PM   #11
TTrx7Pete
TTrx7Pete's Avatar
LOL. Sorry, Lawyer. Argue for arguments sake.
1993 AW Mazda RX-7
1997 Nissan Silvia
