Old 10-16-2008, 07:57 AM   #1
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Well, I dont know what is normal but as you increase valve overlap you're going to decrease you vacuum at idle. If everything else on your car is fine I wouldn't worry about it as the reason you installed cams is to have more power at top end. Cams with above stock duration and lift will cause lower vacuum readings in lower rpm because you are sacrifcing the low end intake "ram effect" for upper rpm gains. "ram effect" being the velocity of the intake air through the runners as it is sucked into the cylinders. look up "ram effect"
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
