Old 10-16-2008, 10:10 PM   #6
Highboost180SX
Highboost180SX is on a distinguished road
Originally Posted by Sileighty_85 View Post
kinda hard for the intake manifold to leak they use metal gaskets
see if you can pull any codes from the ECU too.
how did you get 165??? Adverage is like 150psi, are you runnging higher comp pistons?
What I should have said was a leak from the manifold, at one of the hoses etc, just wondering if any of the hidden ones are prone to failing and how could I test it. The car is running a PowerFC, and I was curious in regards to the high compression test numbers as well. I chalked it up to carbon buildup on the pistons. The car was imported used from japan so I am not 100% sure whats in the block but I am pretty sure its stock.
Highboost180SX is offline   Reply With Quote
