Old 10-03-2008, 08:49 PM   #1
alty319
alty319 is an unknown quantity at this point
Send a message via AIM to alty319
s14 breaks up bad..bad maf?
so i took my car out last night and out of the blue it acted like i was running out of gas..just kept breaking up and hiccuping. Smelled really rich almost like the coolant temp sensor was gone and it was just reading a cold car and running rich. I unpluged the MAF and obv it doesnt rev past 2200rpms but it hunts for an idle and/or stalls out. Anyone know whats going on or had similar problems..? I just changed the plugs also..
Thanks
Rob
D2 RS Coilovers for Sale/S14 Kouki CF Hood For Sale
alty319 is offline   Reply With Quote
Old 10-03-2008, 08:53 PM   #2
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
fuel pump?
Ben G is offline   Reply With Quote
Old 10-03-2008, 08:57 PM   #3
alty319
under wide open throttle its revs out..but light pressure on the gas and it breaks up so bad..black smoke and all..
Old 10-17-2008, 07:34 AM   #4
alty319
so its not the maf because I disconnected it the other day and it still breaks up. seems to be running pig rich.. coolant temp sensor???
Old 10-17-2008, 11:01 AM   #5
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
you are kinda answering your own question.
unplug the cts, no change = your problem.
if it gets worse... then its something else.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-17-2008, 02:43 PM   #6
alty319
thanks I did unplug it and nothing changed. ill try a new one see what happends
Old 10-17-2008, 04:35 PM   #7
alty319
new cts..still runs like crap..but when i tap the MAF sensor the car dies..? But even when its unplugged it pops, sputters..not as bad though.
thanks again.
Old 10-18-2008, 12:00 AM   #8
SqueekyClean
SqueekyClean is an unknown quantity at this point
Thanks
Rob
It could also be a bad injector. I just did a job, where the #2 injector didn't squirt.
An easy way to check is pop up the fuel rail and injectors, have a sheet of paper under it, semi crank the engine, YOu will see the injectors squirt, paper with fuel on it is good injector no fuel on paper = bad.
Remember, cars are easy.
1. Fuel
2. Air
3. Spark
So you just have to eliminate one by one.
1. Fuel - Common: Pump, Injectors
2. Air- Common: IAAC valve , Vaccum, MAF
3. Spark- Common: DIstributor, Coil, Plugs and wires, (Ignition Timing)
These are most common entities that will tend to go out.
SqueekyClean is offline   Reply With Quote
