Old 10-21-2008, 09:46 AM   #1
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
any tips on removing the purpled tint? i got the same shit on mine...
DataXUnknown is offline   Reply With Quote
Old 10-21-2008, 12:15 PM   #2
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
take a trash bag, cut it open and tape it to the window (securely) leaving the top open. pour/spray some ammonia in it (or cleanser with ammonia) and let it sit outside in the sun for a little bit. the ammonia should break down the glue and it'll come off in sheets.
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 10-21-2008, 01:40 PM   #3
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
exactly, I'd also turn on the heater
hopefully the tint isn't too bad or you'll end up scraping it off
JRas is offline   Reply With Quote
Old 10-21-2008, 01:42 PM   #4
carcrzy920
Trader Rating: (24)
carcrzy920 is an unknown quantity at this point
Feedback Score: 24 reviews
yea mines bad so i had to scrape it off. i never thought about the heater tho. i might go try that right quick.
carcrzy920 is offline   Reply With Quote
Old 10-21-2008, 01:58 PM   #5
JRas
JRas's Avatar
I had to do the same took time but it came out good
get a pack of razor blades and a shop vac
unplug your thermal rear window thing as when you scrape the tint off you will ruin it
Old 10-21-2008, 03:44 PM   #6
carcrzy920
Trader Rating: (24)
yea that heater thing is working really good. im almost done with the rear window. thanks
Old 10-22-2008, 03:56 PM   #7
Pank
Pank's Avatar
hopefully you were careful with the rear defroster traces. scraping at it WILL kill them. post pix of before and after
Old 10-21-2008, 01:32 PM   #8
carcrzy920
Trader Rating: (24)
all im using is a razor blade and windex. scrap off the tint with the razor blade then take the windex spray the window and scrap it again with the blade to get the glue off. then just clean it and it should look great.
