![]() Join Date: Nov 2005
socal fs: '90 FC RX-7: street or track, fully built!
i have a built FC that i'm wanting to sell to finish my other full-blown race car.
car is registered and JUST GOT SMOGGED!!!!!zomg ![]() ![]() ![]() ![]() ![]() ![]() ![]() so what's it got? a lot! here's the mod list. i've got like 9k+ in this thing...all it really needs to look proper is a kit and more aggressive wheels. I wanted to do a GP sports or BN kit and then some viennas....but yeah. not sure if i wanna continue and mod the knuckles and stuff too... here's everything.. as far as motor goes, i spent 5 grand and had ROTARY POWER rebuild the entire thing. this shop is the shit. they built ross petty's FD and it lasted the whole season and then some getting beat on with the same motor. its got ALL new housings, fresh port, all new seals, this thing runs so fucking good, it has mostly only track miles on it, but i drove to the track and back a couple times and it's a champ. in the dead of summer at willowsprings, i never see over 92deg in coolant/oil temps. i built the motor to be simple is better, it's a stock turbo thats pnp'd, and top mount intercooler. i'm running like 11 lbs and it makes around 240-250 to the wheels as it sits. with a 60-1 or another simple bolt on turbo, and injectors with a fmic it'll do another 100hp easily. the motors built for 400+. $8,500.00 oboooo ![]() --------- Suspension > 1. Front=CUSCO COMP Coil over+Camber Plates > 2. Rear=MazdaSpeed Coil over 4way adjustable + RE Amemiya solid Strut Upper Mount > 3. SuperNow Ball Tie-Rod End. > 4. URAS Steering Angle Spacer > 5. Racing Beat SwayBar Front+Rear (rear's off, for drifting..) > 6. KTS Rear Camber Ajuster > > Drivetrain > 1. ACT Street Light Flywheel > 2. Exedy Daikin Clutch Disc & Cover > 3. TOMEI T-TRAX 2WAY Clutch type LSD > 4. New KOYO Clutch Master Cylinder > 5. New KOYO Slave Cylinder > > Brake > 1. Endless NA BrakePad (Front) > 2. Project U D-Force BrakePad (Rear) > 3. Endless DOT-4 Racing Brake Fluid > 4. StainlessSteel Brake Lines > 5. Drilled Slotted Rotors X4 > 6. ABS Removed > 7. MazdaTrix Brake Line Bypass Unit > > Exhaust > 1. KSP (attain) 2.5in DownPipe with Bosch O2 sensor > 2. KSP (attain) 2.5in test pipe with WideBand O2 sensor adaptor > 3. GP Sports Dual Catback 2.5in > > Fuel System > 1. Walboro 255L/min Fuel Pump > 2. Dropping register Jump > 3. SARD Fuel Pressure Regulator Limited Gold > 4. Earls Fuel Hose > 5. Custom S4 Secondary Fuel Delivery Pipe > 6. Cleaned 550cc Injectors X2, RC 1000cc x2 secondaries > > Engine Bay Modification > 1. RE Amemiya Strut Tower Bar > 2. Throttle Body Double Throttle Cancel > 3. Emission parts ALL Deleted include Air Pump, EGR, Solenoids, etc > 4. Air Flow Meter Removed > 5. Aluminum 2.5in Intake Pipe + Cone Air Filter > 6. KOYO 50mm Radiator > 7. Aluminum Radiator Cooling Panel > 8. APEXI MAP Sensor > 9. FD3S Intake Air Temp Sensor > 10. Greddy Profec-A Boost Controller > 11. Dual Belt Pulley > 12. Aluminum Oil Catch Can > 13. Rigid Engine Torque Damper X2 > 14. Custom Ported Compressor Housing Turbo > 15. HKS Blow Off Valve (old-school racing one) > 16. MazdaSpeed Engine Mount > 17. TANABE Lower Bar > > Engine Management + Interior > 1. APEXI FD3S Power FC + Commander Boost 1.0kg/cm2 Tuned > 2. Greddy Full Auto Turbo Timer > 3. Omori Water temp Gauge > 4. Omori Oil temp gauge > 5. Omori Oil pressure gauge > 6. Greddy Boost gauge > 7. Greddy Exhaust Gas Temp gauge > 8. Greddy Fuel Pressure Gauge > 9. MOMO Corse Steering Wheel + MazdaSpeed Hornbotton > 10. GREX ShiftNob > 11. magic garage Full Bucket Seat + 4p Harness > 12. CUSCO Rear Strut Tower Bar > 13. RAMSPEED Rear Hatch Bar > 14. S5 NonTurbo model 9000rpm cluster. > Exterior > 1. HID head light 6000k > 2. Front Bumper Canard X4 > 3. Msports FRP 20mm front wide fender > 4. R33 Skyline GT-R Rims 17X9+30 X4 > 5. VOLK GT-V 17x9 +28 x2 > 6. Nightpager 25mm Wheel Spacer X4 > 7. RE-Amemiya Rear Skirt 8.R-Magic Clear Blinker Lens ...whee. ![]()
MANWOLFS|HotLine|Falken|Exedy|DSTROYR|Factory 83|326power| Last edited by Oilcover; 11-07-2008 at 02:55 AM.. |
I rode in this car.
it is AWESOME. I don't think it needs a kit at all. This is old school MARIONETTE style. Immamura (drift samurai) style. Total bummer you are selling it.! ![]()
http://bhworld.wordpress.com/ |
#4 | |
![]() Join Date: May 2005
Oh I hate you sir.
Good luck selling this sexy beast.
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
#15 |
