New Headlights
How do you take the cloudy/ yellowish tint out of the headlights. ive got a 96 and dam i cant even see my bulbs in the headlight. can anyone tell me how to fix em or do i need to get new ones?
Zak |
OMNOMNOMNOM
![]() Join Date: Dec 2000
Reading the Archive and FAQs section does wonders. So does search...
http://www.zilvia.net/f/showthread.php?threadid=15519 PS: Ever heard of the Edit Post feature? |
![]() Join Date: Jul 2002
![]() Ok, you have to trust me on this one. Wet-sanding does wonders. When I did my front end conversion, my headlights, looked like, well, like yours. So I decided that the mis-coloring was on the outside, so I took a 2000 Grip sandpaper, and wet-sanded the lens, trust me, it works.
![]() Join Date: Sep 2002
Could be on the inside if the calking has a leak. If so, just put the headlight in the oven at a low temperature for 5 minutes and peel it apart. Get some silicon to re-seal it though.
98 White S14 |
#8 | |
Yellowish Tint
Guys,
Nail Polish remover or Acetone with some hard elbow grease and a shop rag. I prfer the microfiber, and watch what it does. I performed above feat on my 95 Kia Sephia and am contemplating on my 95 240sx SE. I will upload the pics once I take a before and after, just be careful with your paint job.
Redline at over 6500 then drop the clutch, but to keep it on full boil use fast upshifts and smile big... ----------------------------------------- ![]() |
![]() Join Date: Jan 2003
i've tried a lot of different things...
nail polish remover, rubbing compound, mother's mag polish, sand/clearcoat. They all work to some degree, but the yellowness is still there. Its more apparent on my car because i have one new headlight and one old one. Of course, no matter what i do they're not going to look the same.
Paul Black and Red ![]() |
My buddy used Spray Nine on his fog lights inside them.
Take them out and remove the bulbs (not too familiar with S13 and if this is easily done) but spray with spray nine inside, slosh around, dump, rinse and repeat as needed. Use a hair dryer to make sure theres no moisture. Good luck.
Who the hell needs a sig anyhow |
Acetone!!!
Actually regarding what I previously posted, the full strength acetone actually ate the plastic housing away on my 95 240sx lights. I would scrub then all of the plastic startedmelting away on the cloth. I fixed by wet sanding. I did use a different type of nailpolish remover than I did on the 240. Wet sand or use soft scrub.
I would use extreme caution using acetone. It eats through just about every plastic known and will eat through paint and other finishes.
I use it to remove fiberglass resin from stuff... and its hardcore. |
#14 |
this may sonud really weird (it did the first time i heard it)
but to clean the yellow film on the headlights use tooth paste and a tooth brush. got rid of all the yellow film on my g/f's mx-3 and if there dull looking. dampin a cloth with some oli and whipe them with it and your done. i know it sounds stupid but it really works |
