Old 11-18-2008, 11:39 PM   #1
jeb
jeb's Avatar
jeb is an unknown quantity at this point
s13 hatch cd player wirirng?
i have a 90 s13 hatch that someone took the original harness out an i cant seem to find a diagram or anything to put in an aftermarket one. can anyone help?
jeb is offline   Reply With Quote
Old 11-18-2008, 11:40 PM   #2
projectRDM
projectRDM's Avatar
www.the12volt.com
Found on Google
Amazing.
FORMERLY R240NA
Old 11-19-2008, 09:24 AM   #3
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Really???????
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 11-19-2008, 01:56 PM   #4
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
go to walmart and buy the nissan adapter plugs then wire it to the head unit and plug it in. they give you plugs for most nissans out there
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 11-19-2008, 02:06 PM   #5
projectRDM
projectRDM's Avatar
If the plugs are cut off how does that help him?
FORMERLY R240NA
Old 11-19-2008, 02:17 PM   #6
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
I was asking myself that same question...
SidewayZ-s14 is offline   Reply With Quote
Old 11-19-2008, 02:53 PM   #7
g6civcx
g6civcx's Avatar
Go the junkyard. Find an S13. The radio is most likely gone but if you're lucky the factory harness plug is still there.
Clip the plug with as much wire legth as possible. Then go home and solder the bare wires on the plug with the wires on the car. You should be able to match colour for colour.
Then you can go to Walmart and buy a plug that plugs into the Nissan harness and has pigtails for your to solder to your actual radio's harness.
Old 11-19-2008, 03:16 PM   #8
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
http://www.robzienert.com/xekushnr/Nissan-Wiring.pdf
surreybc is offline   Reply With Quote
Old 11-19-2008, 10:06 PM   #9
projectRDM
projectRDM's Avatar
Better yet, get the car going at an acceptable speed, say 45MPH. Once the speed is set aim it for a solid object like a tree, wall, or building, jump out and do a 'tuck and roll' move, and watch it crash into said solid object and burst into flames.
FORMERLY R240NA
