![]() Join Date: Aug 2008
For the Love of Nissan Just recirculate the Bov
For people that don't know:
Vented to atmosphere is not a good option for nissan tunes. you will have running issues that can be easily remedied by a simple recirc hose. believe me, i went vta at first and never again on the altima. reliability is on par with a non turbo setup, has great blow off sound still and runs like a champ - 11lbs all day long. recirc it, youll be stubborn about it at first, but its the right thing to do and youll be much happier in the end. this is stickied somewhere but here it is again. From: "Ben Pila" <[email protected]> To: <[email protected]> Subject: Re: BOV Setup Information Date: Mon 10/29/07 05:42 PM At 05:35 PM 10/26/2007, you wrote: Hey Ben, one more question I should have asked before... Is the JWT tune designed with venting to atmosphere in mind or with recirculation in mind? I currently have mine venting to atmosphere, but Im hearing that I might have idle issues with that setup. Thanks Jay Hi Jay, The Nissan control system was not designed to run a BOV to atmosphere. There is no way to make the ECU work with this as the amount of air flow in the system that is lost if an atmospheric BOV opens is an unknown amount to the ECU. Once the air flow comes across the MAF sensor, the ECU expects all that air to be in the system and adds the fuel based on this amount. So if you do not want to have the stalling when coming to a fast stop and/or the rich conditions between shifts, we recommend you run a recirculation type valve (also known as a compressor bypass valve). It might be possible to convert your existing valve to the proper type. Check with the company that made your BOV for this. Note that the air flow when recirculated, should dump back to the inlet side of the turbo and ideally aim at the compressor wheel in the turbo inlet. This also helps keep the turbo more responsive between shifts. Best regards, Ben Pila (Technical and Sales Support) Jim Wolf Technology, Inc. 212 Millar Ave El Cajon, CA 92020-4219 (619) 442-0680 Mon-Fri 8am-5pm PST (619) 579-8160 24 hour fax JIM WOLF TECHNOLOGY, INC. / NISSAN PERFORMANCE / NISSAN RACING /INFINITI PERFORMANCE
S14 Turbo LS1/t56 http://www.playloudclothing.com/ |
QFT the sound is priceless. I think a lot of people beat the shit out of thier cars here and i don't really think a BOV will break something faster then driving the cars like we stole em.
![]() Join Date: Jan 2004
my s14 that i bought for track use came with an atmospheric setup and i'm too lazy to recirculate it :-P
D-Street.net | bcuison.wordpress.com |
#17 |
#19 |
how did you run it like that? cause i want a blow-thru i just dont want to be burning up mafs regularly since z32 mafs are really hard to come by in PR and waiting for someone to post one up and hope its working fine is kinda shitty
#20 |
![]() Join Date: Nov 2006
Im with this guy. I know alot of people on this forum dont run blow off valves either. To me aslong as you dont hit full boost than let off to let it surge over and over everyday than it wont hurt. Its those people that Hit boost in first gear in the middle of town just to let it surge that fucks their turbo's up.
92 vert converted 5speed and other little things |
#21 |
most of the SR guys here just replace that one pipe you guys all attach the BOV to with a solid pipe, the upswept one on the side of the motor. sorry im not too SR savvy.
#24 |
![]() Join Date: Apr 2007
get an hks ssqv. Never have to worry about running atmospheric/stalling.
"I am Norwegian, and are not familiar with your urban words :P" |
#28 |
with the idle air hooked up you shouldnt have any trouble with stalling. my BOV has been vta since day 1 and the only time i ever had an issue was before i had the idle air tube hooked up.
now i have never once had an issue. runs like a dream. |
#29 | |
This idle air tube you are talking about, where is it located? (on the throttle body?) where does it hook up to? maybe this may solve my problem. |
#30 |
its a big tube, like maybe 1" or so, its on the TB i think, or maybe just the intake. i dont have my car here to look at it. but there should be a hose going from that to your cold pipe.
heres a pic of my motor, you can see the tube, just not really where it goes. ![]() |
