![]() Join Date: Mar 2002
Review: SPEC Stage II clutch and Fidanza FW installed
I just finished the installation of my SPEC Stage II and Fidanza Flywheel. The installation was horrible.
Day 1: I did everything to spec. Found that I had a sprung 3puck clutch which had no friction material left on it (which explained all the chatter) but ran out of time so I had to leave the auto hobby shop w/o finishing Day 2: after bledding the clutch system for two hours we couldn't get the tranny to go into gear at all. Fought with it for a couple more hours and decided to buy a new Master Cyl and Slave to remedy the problem Day 3: Found a great deal on both the master and slave for $50 picked them up and installed them in 20 mins. Began to bleed the system again and the same results. I called SPEC to inquire but they had no good suggestions Day 4: Took tranny back off and inspected all work and torque specs and found nothing. Tried using the old pressure plate but the clutch disk was too thick. That is when I called Ken at Enjuku and he told me to take off the clutch dampner. Worked like a charm and I finnally had pressure in my clutch pedal. Adjusted free play and I was in business. Review: I added Redline 75W-150 which made the tranny feel great very smooth. I reccomend it strongly! Although I can't really get on it with high boost, but the new flywheel feels great very quick revving and effortless throttle. The pressure plate is too soft so I have to get used to a touchy clutch peddal (I was spoiled by the three puck w/ stiff pressure plate) but it will be better in traffic ![]() I will do a write up w/ pics but word to the wise- If you can't pressure bleed your clutch system get rid of the dampner ASAP or you will not get all the air out. It will save you a lot of time and aggravation ![]() Edit: to bypass the dampner follow the hard line from the master across the fire wall and down to the underside of car. Unscrew the fitting. Find the slave on the tranny and follow the soft line to the dampner box. Unscrew the fitting. Bend the hard line from master to meet slave and use the same bracket that the soft line was in. Then viola! No dampner. You can remove the dampner now.
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP Last edited by nrcooled; 01-04-2003 at 04:28 PM.. |
![]() Join Date: Apr 2002
are you running stock boost? I was thinking about getting a spec clutch but I wasn't sure if I should get the Stage 1 or 2. If I don't go much higher than stock would there be a point of getting the stage 2? It's gonna be at least a year or more before I can do the nesecary upgrades I. intercooler, fuel upgrade etc....
89 S13 hatch/////98 Subaru 2.5RS |
You can run max boost of the t25 (14psi) w/ the SMIC and stock injectors. You won't see any problems unless you are running in extreme heat and humidity. I am running 11psi daily w/ no issues.
About the SPEC stage II I talked to Ken at Enjuku and he said that it should be more than enough for my massive 205hp 215lb/ft tq at 10psi. It's also so much more streetable than the 3 puck that was in there before
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP |
nrcooled, your clutch should be broken in by now... as this is kind of an old thread.
![]() In any case... Does/did your Stage II chatter at all when you first got it in? I just put mine in a few days ago (at a shop) and even pulling out of the garage, it was "shuddering" or "chattering" at low rpm (sub 1,500) when slipping. Bringing it up higher (>1500) rpms, slipping does not cause chattering though. I realize you're using a fidanza lightened flywheel, but that shouldn't make much of a difference. Others: are new slightly-stickier-than-OEM clutches like this supposed to chatter at low RPM slipping? Or did the shop **** up the install?
Instagram: @SX180HKG |
#6 | |
-sorry it took so long to reply ![]() ![]()
Nuclear
I'll post a second opinion in a couple of weeks when my OEM flywheel gets lightened and I slap on the Stage II.
RACECAR spelled backwards still spells RACECAR |
I threw my SPEC II on with a JUN flywheel on my S13.. The bastard chattered at low rpms. It was hard shifting into gears so I adjusted the clutch pedal height. If you don't then you'll probably damage your tranny gears like I did with mines..
I don't know about SPEC clutches man.. Someone tell me.. |
Related to the SPEC clutches....
I my hope clutch doesn't chatter when I get the car running. I'll be sure and post when I get evertyhing going. Anyway,
Did you guys use the throw out bearing that SPEC sent with the clutches? I put my clutch on with it, and the bearing was kinda weird. I spun and it kinda walbled (sp?) I'm hoping it will correct itself when the car is running.....
![]() Join Date: Dec 2002
Trader Rating: (39)
![]() Feedback Score: 39 reviews
I dont have any problems with my stage II, but I just put a new slave cylinder and I am gonna have to remove the dampening box cause bleeding it sucks.
As of right now I like my clutch, I have only been cruzing at stock boost and have had no problems as of yet. Although I am kinda worried about it, my friend had a stage III and the pressure plate lost all pressure and fried his clutch in less than six months. I just hope this doesnt happen to me.
1997 Nissan 240sx 1991 Nissan 240sx hatch |
just to review/recap now that it's been a while... my stage II only chatters at ~1,200 rpm when starting from a stop. (happens whether I start in 1st or 2nd.) above that, and after the clutch has fully engaged (after I've taken my foot off the pedal) then there are no problems. Upshifts and downshifts (1-2, 2-3, 3-2, 4-3, etc) are all smooth and I feel nothing out of the ordinary.
AFAIK the clutch was installed using the TO bearing supplied by SPEC, but there's still that annoying noise (sounds exactly the same) when I'm at a stop (idle) and the clutch is in (engaged) in neutral. It goes away when I push in the clutch, JUST like before, so I'm somewhat unsure of whether the new throwout bearing was installed with the clutch or not. That, or there's something awry somewhere else in the tranny/clutch area!
#13 | |
Trader Rating: (39)
#14 | |
![]() Join Date: Mar 2003
Re: Review: SPEC Stage II clutch and Fidanza FW installed
#15 |
![]() Join Date: May 2002
It does what it says - it damps the vibration/shock from the clutch and slave cylinder from the master cylinder and clutch pedal. Mostly to make the pedal feel smoother, and possibly to protect the master cylinder... but those master cylinders fail all the time for other reasons anyway.
#17 | |
I used the SPEC T/O bearing and installed everything according to the Chiltons manual. Took my time to make sure everything was done correctly. I have had no noise (or maybe I can't hear it over my chattering OBX SS or exhaust) and no chattering. The only way to be completely sure is to do it yourself I guess
![]() Shops make mistakes and don't tell you or don't know they did. If I make a mistake I know exactly what/ what not I did. Quote:
Ken @ enjuku said that they could get pressure but after they took their project car out the clutch pedal would just sink to the floor again. I couldn't get pressure at all. I bled and bled but the da_mn pedal wouldn't get any pressure
