Old 12-03-2008, 06:10 PM   #61
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
in conclusion... you want to keep your luxury... just put on some light weight wheels and remove anything you really don't like, and the normal carbon/FRP things...
not much you can do beside those if you want to keep the car stockish...
bejota180sx is offline   Reply With Quote
Old 12-11-2008, 04:52 PM   #62
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
How much weight would you save going with Fiberglass or CF trunk. I can't imagine the weight savings would be that much.
Also, a question for all those who have taken out the sound deadening. Is there that much of a difference afterwards?
guitaraholic is offline   Reply With Quote
Old 12-11-2008, 05:29 PM   #63
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
I think making drivetrain lighter is better than making the overall car lighter for the 240.
moses is offline   Reply With Quote
Old 12-11-2008, 05:37 PM   #64
zorak
zorak's Avatar
zorak is an unknown quantity at this point
Send a message via AIM to zorak
Originally Posted by Hashiriya415 View Post
why weight reduction?
some of my ideas
remove all speakers, stereo. that's how I roll, everyone that rides with me always says why don't I install a stereo, do you have to have a stereo?
1 windshield wiper
remove airbags
remove blower motor and replace with a computer fan, seriously that saved me like 5-10lbs
no carpet, you can afford shoes right?
motorcycle battery, that's about 20lbs
I took lot's of time removing wiring, door sensors, S13 automatic seatbelt wiring, basically after all the unnecessary S13 crap I shaved around 20lbs
no rear brakes, only if you think you are doing the right thing
no power steering
remove unnecessary wing, side skirts, if you have a bigger aftermarket bumpers
racing shoes, they are so light you don't even feel your wearing them, sometimes I just drive with no shoes
sun visors, just relax and enjoy the sun
cut bumper support, or remove completely, you make big money when someone hits you, cuz my zip-tied bumpers will fall as soon as another car touches them, they fall off and money gets transferred
lighter exhaust, stainless steel headers, catback, or even titanium if you got the money
aluminum shift knob, custom aluminum e-brake
shaved off the 4 S13 side markers
remove fog lights
remove 1 horn
short intake
intake manifold
small K&N oil filter
1 quart less engine oil, even 2 worked on my friends B18 that I raced with, but he had royal purple so that's why it didnt blow probably
half quart less, tranny oil
brake fluid right at the low line
use old brake pads almost worn out, that's about 5lbs for all 4
remove power antenna
if you have a KA, go with SR20DE
lightweight pulleys
cable and lever, for trunk and gas door, after you remove this you can't open the gas door unless you kind of bend the little latch inside, so basically on mine now, I hit it and it opens.
instead of screws and bolts that hold unimportant things just make little weld
carbon fiber driveshaft, light and increases safety
coilovers with aluminum body, so far haven't found anybody making them, someday I'll try making some
2 piece brake rotors
aluminum brake calipers
somebody really needs to make the front and rear sub frame out of aluminum
glove box. Passenger "I'm just gonna put this in your glove box, hey were is it?" me "glove box, never heard of it"
gauge cluster, just get tach and temp gauge
custom aluminum clutch/brake/gas pedals
lighter tires
knife instead of gun
acid dip doors hood trunk
Or you die. whichever.
Oh and no carpet and driving barefoot = 100% Fail.
zorak is offline   Reply With Quote
Old 12-11-2008, 06:14 PM   #65
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Originally Posted by georgesal View Post
or just make more power
weight reduction is more than just making power it improves handling.
it adds up, even shaving ounces
guy at the track with a civic, cut off the extra threading from every bolt I saw in the engine bay.
JRas is offline   Reply With Quote
Old 12-11-2008, 07:33 PM   #66
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
"If you wanna lose pounds, count the ounces."
SochBAT is offline   Reply With Quote
Old 12-11-2008, 08:16 PM   #67
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
Originally Posted by Kalashnikov View Post
Ways to reduce weight on a 240sx by Kalashnikov:
1. Cut off all the Muffler bearings, You don't need them.
2. Empty the catalytic converter fluids
3. .....
haha.
remove::
paint
one lug nut from each wheel
seat belts.
Marcus is offline   Reply With Quote
Old 12-11-2008, 09:21 PM   #68
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
remove girlfriend
WangonwWarrior is offline   Reply With Quote
Old 12-11-2008, 09:34 PM   #69
jamben
jamben's Avatar
jamben is an unknown quantity at this point
throw it away. or drift into a wall
jamben is offline   Reply With Quote
Old 12-11-2008, 10:14 PM   #70
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
-donate blood, trim nails, cut all hairs on body, get circumcised, cry, sweat, take a crap, pee, and puke before you get in the car
-give ur girlfriend some bus tokens
-drive naked
-while driving, keep spitting out the window
these are probably the only things left that you can do since you want to keep all the nice things in your car. dont get me wrong. i totally understand you cuz i like my baby looking like a car on the inside too. the first time i tracked her, i took my pants off and drove in boxers. i should've taken my shirt off too.....
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 12-11-2008, 11:09 PM   #71
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
Does anyone here actually have a dedicated track car?
Or are we just trying to find that delicate balance of performance and pimp?
kognition is offline   Reply With Quote
Old 12-11-2008, 11:20 PM   #72
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
just picked up an xtune header, it fits perfectly, and its about 5x lighter than the s14 mani
Bigsyke is offline   Reply With Quote
Old 12-12-2008, 01:34 AM   #73
Def
I wouldn't call it a dedicated track car, but my S13 is definitely not my daily driver. It averages about 3-4k miles, with at least a good bit of that(or as much as possible) going towards "driving driving."
Old 12-12-2008, 02:31 AM   #74
Devius
Devius's Avatar
Devius is an unknown quantity at this point
HAHAHAHAHAHAHAAAAAAAA!!!!!
Devius is offline   Reply With Quote
Old 12-12-2008, 07:02 AM   #75
g6civcx
g6civcx's Avatar
If you do something to make the damage worse, like modifying your vehicle, that's contributory negligence and you may be denied compensation because you are responsible for the damages you helped cause.
Also none of this applies in no-fault states.
You have been warned.
