#2345 |
![]() Join Date: May 2003
6k springs, tension rod nut/bolt to 71115?
Also, anyway to get the click adjuster things or how to fix one, both of my front ones seized up, rear ones work fine for some reason.
Hookers and blow. |
#2346 |
$76
I've never had one of the adjusters seize, but if you force it against the end of the adjustment full soft or full hard, then it requires the same force to turn it back. I imagine that the damper shaft shaft being steel, if there was water down the adjustment hole it could cause some rust. Obviously this would never happen in the rear because the adjusters are in the interior, but it is possible in the front. If this theory is correct, I would blow some compressed air back and forth across the adjustments hole to get any standing water out and then hit it with some spray lube, get it free with a hex wrench, then make sure you get out the excess lube.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#2347 |
Number one!!!!
finally installed my piro tension rods.
http://bhworld.wordpress.com/ |
#2348 |
Thats hot. I missed you on sunday man
#2349 |
Yeah me too.... stayed home to try and finish my car.
#2352 | |
Tracking emailed, thanks!.
#2353 |
A couple of Hybrobrake updates:
My video focusing on the Hybrobrake use at Horse thief mile.... http://www.youtube.com/v/GkaNrnwAyzM&hl=en&fs=1 Heres the install on Dave Blunt's Drift Spec BMW I love this car! ![]() ![]() FYI the rear brake line splice point on this vehicle is after the porportioning valve near the frame rail in the engine compartment. ![]() ![]() ![]() ![]() ![]() ![]() MAX Hydro Brake Version 2.0 In stock in the USA NOW! Standard Hydraulic side brake version two features include: ~More brake line pressure ~Willwood master cylinder ~Adjustable bump stop ~Steel tranny housing reinforcement plate ~Extra long handle ~Heim joint linkage ~Delrin Bushings ~Bomb proof steel case ~Foam rubber grip $220 + Shipping + $80 for Earl's Stainless steel lines and fittings Tension Rod Handle option is $100 extra.
#2354 |
Rear toe rod for an s13 shipped to 20855. Also do you really think it is necessary to get the 2 gen toe rods? I mean how low can i go before im gunna need that bend in the toe rod? Thanks
#2355 |
$195 shipped for G1 toe. You need to spend $20 more and get the G2 Toe if you want to get gangster like this:
#2356 |
![]() Join Date: Dec 2006
just wondering with the the hydro brake... do you still have to press the clutch to actually lock the brakes, or does it create enough pressure to actually stop them...
idk may seem like a dumb question, but i'm just curious.
#2358 | ||
There is all types of situations in which you would use the brake, but typically if you would want to lock the rear wheels coming into a corner you would A) aproach the corner overspeeding B) Initiate drift early C) push in the clutch D) hold the lever E) steer towards the apex F) mash the gas G) dump the clutch and release lever at the same time for the second half of the corner drift & corner exit Quote:
Taniguchi talks about this, he uses the side brake in a manner that does not lock the rear wheels so that the crowd/judges can not see the sudden change. The Drift flows better and appears more seamless & creates a look that is less abrupt or jerky.
#2359 | |
![]() Join Date: Apr 2005
![]() Quote:
Completely locking up the wheels is the wrong way to go about initiating a drift anyway you lose momentum and the car's handling is greatly upset and will most likely send the car into an uncontrolled slide (possibly into a solid object) rather than a nice smooth controllable drift. Smooth driving techniques are paramount as Taniguchi states in his techniques. I wish they'd teach this sort of stuff in basic driving school I'm sick of dodging people who can't seem to properly control their vehicles. But anyway back on topic. Buy from these guys they know what they're talking about and their shit is top notch. ![]()
There's not enough hours in the day. |
#2367 | ||||
![]() Quote:
$20 shipped Quote:
$17 shipped Quote:
$100 ea for a 100% new damper no problemo
#2370 |
$20
Tracking emailed. It should be there this week.
