Old 12-14-2008, 11:17 PM   #1
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
clutch throw out bearing problem
of so 2 days agao i had my friend who is a certified tech change my cluch. i bought a used exedy stage 1 clutch/pressure plate from a friend with 2k on it.
i go to the nissan dealership next to my work and get an oem throw out bearing. we get it back in and everything and we turn it on to bleed the clutch and to test it and when i hold the clutch pedal down it makes a loud sceeching noise and a quite a bit of smoke came from under the hood. so my question is could an sr oem throw out bearing work with the stiffer pressure plate or would i have to get a exedy one?
thanks all
civilized_drifter is offline   Reply With Quote
Old 12-14-2008, 11:20 PM   #2
Sileighty_85
Sileighty_85's Avatar
Sounds like someone pressed the TOB on the sleave backwards
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-14-2008, 11:34 PM   #3
civilized_drifter
i had bought 2 throw out bearings cause there were 2 different part numbers. so it might be just that its reversed? but would the stock one be strong enough for the upgraded pressure plate?
