Old 12-19-2008, 08:07 AM   #1
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Ok do the simple shit first. Like others have said: spark plugs and timing.
Then if that does not work you might try getting your injectors rebuild. I had mine done for about $100.00 for all four. Make sure if you do that they use OEM seals! All the after market seal kits that I have found for the Nissan SOHC injectors are a hair too small and they leak.
I found that when I did mine the car rans so much better. Better mileage, ran way smoother, and almost passed smog. All four were leaking is what the tech said.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
