Old 12-20-2008, 11:10 AM   #1
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
possible deadly situation?
Hey guys I've got a question about the potential of me bursting into flames along with my car.
I'm yet to drive it like this, but in an attempt to get my exhaust (buddy club spec II) hanging higher, I have it rigged up to where a point on the exhaust about 1.5 feet from the tip is touching the gas tank.
Question is... I know heat+gasoline=bang, but does the back end of the exhaust create enough heat to cause a problem with touching the gas tank.
The resulting ground clearance would be cantankerous, though.
P.S. I hate the exhaust tow hook
slothonaleash is offline   Reply With Quote
Old 12-20-2008, 11:12 AM   #2
YoungGun
YoungGun's Avatar
I think you're missing the spark for the BANG.
YoungGun is offline   Reply With Quote
Old 12-20-2008, 11:15 AM   #3
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
LOL 'cantankerous' must have been one of your vocabulary words in school this week.
Sorry bout that, I just found it funny.
To answer your question, I wouldn't think that having the exhaust touching the fuel tank would be cause for panic, though I would only recommend driving it when necessary. The heat generated there shouldn't be enough to ignite anything. Be careful you don't wear a hole in the tank though, I had a friend have that happen in a Del Sol and it ended up catching on fire taking off from a stop sign cause it backfired and lit up the fuel underneath the car. Was kinda funny to watch it happen though. Luckily he had an extinguisher behind the seat so the only thing damaged was the fuel pump wiring.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 12-20-2008, 11:16 AM   #4
slothonaleash
Ignition point for gasoline is 495 degrees fahrenheit.
I'm guessing you only get those kinda of temps in the manifold and a little further down? (seeing as though my car does after fire every once in a while)
edit:
sounds good phantom... I'll put some kind of buffer between the tank and the exhaust maybe (bike innertube or something ghetto of the sort)
and I'm known in class for my incorrect use of my multifarious vocabulary
thanks guys
Old 12-20-2008, 11:18 AM   #5
LA_phantom_240
You mean backfire?
Old 12-20-2008, 11:21 AM   #6
slothonaleash
Originally Posted by LA_phantom_240 View Post
You mean backfire?
It's my understanding that backfire is an explosion through the intake manifold/carb
Afterfire occurs through the exhaust
Back-fire - Wikipedia, the free encyclopedia
I dunno
you understood what I said haha
Old 12-20-2008, 11:26 AM   #7
LA_phantom_240
I dunno
Indeed.
fknmsglgth
Old 12-20-2008, 11:31 AM   #8
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
are you guys serious?? Ive seen countless rear bumpers melted, and yes on a hot summer day it can very well get up to 500*+, the manifold can get around 1300*f.
My NA KA24DE shoots flames out durring decel......theres your spark
Bigsyke is offline   Reply With Quote
Old 12-20-2008, 11:37 AM   #9
xkamikazestormx
xkamikazestormx's Avatar
xkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfection
because the end of your exhaust is where the gas tank is
xkamikazestormx is offline   Reply With Quote
Old 12-20-2008, 12:21 PM   #10
S14DB
AFC #1
S14DB's Avatar
Ever put a paper cup of water over a burner? The water will boil before the cup burns.
Gasoline only burns as a vapor not as a liquid. You would have to boil off the whole tank for it to ignite. I don't see that happening 1.5 feet away.
Old 12-20-2008, 03:09 PM   #11
1ZlowZ
1ZlowZ's Avatar
1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute
Edit: nvm im stupid i rwad wrong.
-Victor S.
1ZlowZ is offline   Reply With Quote
Old 12-20-2008, 03:21 PM   #12
Def
Just wrap that part in header wrap and safety wire it in place - no more worries and it won't take more than a few minutes. Wrap other stuff in header wrap that gets hot and enjoy [Best Motoring Voiceover Announcer Engrish]cool driving[/Best Motoring Announcer Engrish].
Old 12-20-2008, 03:27 PM   #13
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
You'll be fine. I have my exhaust routed through my gas tank.
Old 12-20-2008, 06:19 PM   #14
Bigsyke
Bigsyke's Avatar
Well under the influence of a purple rain, I guess I read the question wrong. But I still hold my case that Exhaust pipes + gas tank = bad,
Old 12-20-2008, 08:47 PM   #15
silviaguy240
silviaguy240's Avatar
forgive my science knowledge and generalization..but it may heat the gas and make it atomize better maybe?
Old 12-21-2008, 07:20 AM   #16
S14DB
AFC #1
S14DB's Avatar
In the tank?
Old 12-21-2008, 08:00 AM   #17
OBEEWON
OBEEWON's Avatar
In the tank?
ahaha...
1.5 feet is good. Ive melted a gas tank before. 1.5 feet is plenty good room sir. That plastic is pretty thick like a chick from hotlanta.
