Old 01-01-2009, 04:12 PM   #1
Leetheslacker
Leetheslacker's Avatar
Leetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond repute
rattle/knock/clunk from front when driving straight
okay. so.
i have this knocking sound that seems to be coming from the front left wheel.
it varies by speed. slower at slow speeds and faster at higher speed.
it seems like i can feel it in the floorboard with my feet when its happening.
if i turn even ever so slightly it goes away.
if im braking it goes away.
i took the wheel off and poked around and everything seemed okay, but something has to be making that noise.
its driving me insane and i have no idea what is causing it. help.
Leetheslacker is offline   Reply With Quote
Old 01-01-2009, 04:58 PM   #2
S14DB
AFC #1
S14DB's Avatar
Warped rotor or the wheel bearing is shot.
Old 01-01-2009, 05:33 PM   #3
B_mart24
B_mart24's Avatar
B_mart24 is a well-known jackass
sounds like maybe a rotor...especially since it varies in speed/ revolution speed
B_mart24 is offline   Reply With Quote
Old 01-01-2009, 05:34 PM   #4
Leetheslacker
you really think a warped rotor would stop making noise when turning?
brakes seem fine. no pulsating pedal or shimmying/shaking when braking. no pulling to either side. the clunking goes away when im braking.
Old 01-01-2009, 06:23 PM   #5
B_mart24
B_mart24's Avatar
idk about turning? maybe its putting enough pressure on it to not make it grind? idk man
Old 01-01-2009, 07:03 PM   #6
projectRDM
projectRDM's Avatar
Either the rotor or wheel bearing would load up just enough to silence a light noise when turning. Check for end play in the bearing as well as fore/aft movement, then move on to the rotor.
FORMERLY R240NA
Old 01-01-2009, 08:40 PM   #7
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
check the lugs. my z did that and then the wheel fell off... they might just need to be tightend.
im young and uneducated btw... hence, dident check the simple shit
93nismo is offline   Reply With Quote
Old 01-01-2009, 10:25 PM   #8
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
check your wheel bearings for play. mine had similar symptoms
lexus baby
5t341tH is offline   Reply With Quote
Old 01-05-2009, 02:31 PM   #9
Leetheslacker
installed aftermarket tension rods finally. stock ones were trash.
noticed one lug on one of my front spacers was kinda loose. tightened it.
noise is gone. so either one of those things or both was causing it.
but my right tie rod end is fucked. tons of play. doh.
