#2704 | |
#2705 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Posted up several times, but here's another.
17x9 +5, 17x10 +19. 215/40 F, 235/40 R. Camber: 3.5* F, 3* R ![]() ![]() ![]() |
#2706 |
I picked up a set of 18x10 +18's with a 255/35-18. Would those work with a roll and slight pull? The tire sizes is kind of wide and i think i need to go with a 235 or 245
#2707 |
![]() Join Date: Sep 2005
i would say atleast 235.i ran a 225 on my old 10 inch wide wheels and it looked sweet.
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
#2708 | |
![]() Join Date: Aug 2006
well i'm running that on a s14. 255/40 17x10.5+13ish |
#2710 | |
![]() Join Date: Jan 2006
it looks okay, looks functional and drivable. but for this thread...needs a bit more poke, a bit more stretch and a bunch more low. |
#2712 | ||
The Architect.
I don't like pulled fenders. I don't like fiberglass either. So, no widebody. Getting new bushings in the subframe this month(Nismo). So, I can remove the collars and have the car sit a little lower than it does now. Quote:
It would look better just a bit lower, but I have enough trouble as it is driving it around. Going lower at this point is only asking for trouble. Dented oil pans and kissing my motors goodbye isn't my thing. |
#2713 |
first off, don't get me wrong, its a beautiful car, stupid clean, much prettier than anything i could ever build.
im just wondering... what coilovers max out at that height? also by collars im guessing you mean subframe collars, that would simply dial out camber a bit more positive, and not affect ride height, correct? speaking of collars, if the coilovers are in fact, maxed out, may i suggest removing your coilover collars from the rears? |
#2714 |
![]() Join Date: Dec 2006
i think the front is super fucking low..... like almost to low... but that is based off ohio driving roads... lol
def can't wait to see the pics of the rear matching the front.... Crimson your car is my current inspiration, until i get ready to go aero and 18's 17s + stock aero + proper fitment = nasty nasty sick
#2715 | |
Did you screw the spring all the way down already? I am assuming you did, but there are a lot of people who forget about it
Battle Idol Works 2015 |
#2721 |
Get something like this: Tanabe Sustec Helper Spring 60mm
and then drop spring the rear. easy. |
#2722 | |
The Architect.
There's zero pre-load. JIC FLT-A2's. From what I've read, subframe collars raise the ride height(don't know for sure though). Hmm, i'll try pulling the subframe collars off and see if that lowers it a bit. I know I can dump the fronts up to the rim by removing the rest of the collars, but I'd rather not. I'll be running a Xenon lip this month. So, I'll want it to sit a little higher than the actual ground. Hah. Another side shot. ![]() |
#2723 | |
If it still isnt low enough for you, you can remove up to 2 of the collars on the coilover and it WILL go down. Here is the difference when I was playing with mine: With the spring not screwed down, coilover max low: ![]() With all three collars touching: ![]() And this is Travis old car with 1 collar removed. Difference between GP and BN aero on an FC is about 1" and his fenders were mounted about 1" higher than mine: ![]()
#2724 |
His car has the Megan Tracks I think, which are 12/10, that's why it won't settle lower even with both bottom collars removed.
You can now buy different length/rate springs from Megan. Megan Racing That's what I'll be doing if I'm not tucking front wheels when the ride height settles. |
#2725 |
![]() Join Date: Nov 2007
No they're streets, thats why I don't get how you guys are so low haha.
Matej, do you know how to interpret those different springs? I see the different spring rates. If I were to buy some I would probably get the 8kg rear springs, but how do I know which one is shorter? Also I may be stupid, but how would a shorter spring lower the rear of the car? The coilover bracket in the rear bottoms out on the actual shock, so wouldn't it just be wobbling around free in there. |
#2726 |
![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
I was on Megan streets and they got pretty damn low for me... *shrugs*
I still had room to go down in both the front and the rear, and that was with no spring droopage, just lower bracket adjustment. ![]()
#2729 |
I think this is the only case in which the phrase "mine is smaller" will actually be manlier lol
"My lower bracket is smaller so I can go lower" "Damnit, I'm ashamed of my larger member..." Anyway... This is on Stance GR+ with the 7k rear springs on it, lower bracket bottomed out on the shock body, and zero droopage or preload on the springs. ![]() 215/45/17 on 17x9 +20 in the rear, no pull, just rolled the fenders flat. With spring droopage, I can tuck the top part of the rear rims. Younggun needs to droop springs. |
#2730 |
Sorry i'm new to all the fitment lingo.
How do you "droop" the springs? I would like to try this right now. My situation is that I have all my collars removed and the lower coilover bracket is bottomed out against the threaded shock part when I screwed it all the way up. |
