Old 01-09-2009, 12:30 PM   #1
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
Helical LSD Alternatives?
For those of us who like "grip" driving I have been told nothing beats a helical/torsen LSD. As of right now it looks like we have three choices, both with there pro's and cons.
OBX
Pro's
- Cheap
- Uses Open Diff Shafts
Con's
- Lack of quality controll/craftsmenship
- Must be shimmed
- MADE IN CHINA (that's personal, but I hate
supporting a country that is going to one day
try to take over the world)
Quaife
Pro's
- Awesome Craftsmanship
- Lifetime Warrenty (even if raced)
- Good customer service/support
Con's
- Very Expensive ($1350 or so)
S15 HLSD
Pro's
- OEM Quality
- Lower cost than Quaife, but still expensive
Con's
- Need to buy output shafts (adds to cost)
OK, that being said I've been reading up on other vehicles that use Helical type LSD. Some can be had for as little as $450 new. They are OEM quality and some of them (like the one for the Firebird) can handle tons of torque. So here comes the question........
What type of custome work would be required to get something not of the same manufacture to fit. I am speculating, that it might require custom fiting of the differential case, and output shafts. This is just an idea I am throwing out there. heck, if its something as simple as drilling a few extra holes for the casing, and come custom output shaft (or machining of some) it might be a cost effective alternative that is OEM quality without spending a grand or more
guitaraholic is offline   Reply With Quote
Old 01-09-2009, 12:38 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
Differential housings are somewhat standard, so if you found out what kind of housing your desired differential is in, you can look around and see about fitting the new housing in your car.
At the very least, you need a custom driveshaft ($200 at least), custom axles (or output shafts), and subframe mods.
It's most likely cheapest to get the S15 diff.
Old 01-09-2009, 12:52 PM   #3
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
just get a S15 HLSD.. I wouldn't say it's the best, all have their pros and cons.
quoted from Brady:
"The downside to a helical is that you have virtually no locking action off throttle, and/or under braking.. it acts as an open diff when you're off throttle. Driving Jeremy's SR20 car at Willow Springs (lots of high speed corner entries) was tough, and the car would have been a lot faster with a clutch diff. With a clutch diff you can blast into high speed corners like Turn 1, or Turn 10 at PIR with confidence, and accordingly, mop up just about anyone else in the said corner.
But, the flipside to that is lockup under acceleration. When you have what is essentially a "solid" axle, or a locked up clutch diff and you try to turn the car, one of the wheels is destined to break traction. That of course turns an otherwise great grip car, into a drift car.
My SR20 car is excellent on corner entry.. stable as a cruise ship. The only major flaw that car has now is the ability, or lack thereof, to put power down on corner exit.. and most of that is due to the tight lockup of the clutch diff. The way to fix that would be reduce preload or grip from the clutch discs, which is why the diff in my KA24 car works well.. the discs are pretty worn out, thus reducing the amount of lockup force, allowing the car to turn and put power down at the same time."
JRas is offline   Reply With Quote
Old 01-09-2009, 12:53 PM   #4
guitaraholic
So why do you have to change the subframe (sorry, not too familiar with how Differentials mount on the car?) I believe you could make up some of the cost of the driveshaft by selling the driveshaft you already have (5 speed DS are hard to find). If you have a rebuildable one (like me,,, one piece aluminum), all you need is to change out the flang. If it uses the same diameter output shafts then I believe all you would need to do is have them machined (length and splines).
Old 01-09-2009, 01:04 PM   #5
murda-c
murda-c's Avatar
What are balltecs?
i remember hearing they worked similare to helical.
don't know about quality or performance or anything, but i think that's an option for ya.
Old 01-09-2009, 01:11 PM   #6
guitaraholic
I've heard two different things about the balltech (at least function wise). I've heard instances where they work like a helical, but use ball bearing instead of gears (not quite sure how that would work), other people have said it works like a clutch, where the ball bearings press against a friction housing and locks up both sides (like a clutch LSD) As for quality, I am not sure.
Old 01-09-2009, 01:11 PM   #7
JRas
JRas's Avatar
I don't know why you want to make this complicated.
get a S15 HLSD.... really not that expensive, I paid $425 for mine with output shafts.
/thread
Old 01-09-2009, 01:13 PM   #8
guitaraholic
I've seen them once in a while go for that much, but usually they wind up going for around $550-$650, then you have to add the cost of shipping from Japan (usually $75-$100)
Old 01-09-2009, 01:15 PM   #9
don_bagz
don_bagz's Avatar
don_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to behold
/thread
id be interested to know where you got yours...
sorry to jack thread
don_bagz is offline   Reply With Quote
Old 01-09-2009, 01:23 PM   #10
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
I got a OBX one for $250 never used and installed in a pumpkin already.
timtiminy is offline   Reply With Quote
Old 01-09-2009, 01:33 PM   #11
S14DB
AFC #1
S14DB's Avatar
Originally Posted by murda-c View Post
What are balltecs?
ƒ{[ƒ‹ƒeƒbƒNLSD@•ª‰ð
Old 01-09-2009, 01:45 PM   #12
guitaraholic
Now I just have to get my sister to translate....lol (She can speak/read Japanese)
Old 01-09-2009, 01:56 PM   #13
hayaimoto
hayaimoto's Avatar
hayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud of
What is this car going to be used for again? STAY AWAY FROM CHINA MADE STUFF unless you want to buy more units down the line when that first one breaks.
hayaimoto is offline   Reply With Quote
Old 01-09-2009, 03:11 PM   #14
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
how about a j30 VLSD, from a forum ive seen before all you need to do is add 1 shim and it be workin as if it was a 1.5 lsd and 2 shim if u want it to act as a two way.
i didnt read about any cons of it. but yeah. try lookin that up.
here the right up about it. iono if this will help you. im thinkin of tryin this myself
http://zilvia.net/f/s-chassis/200226...-j30-vlsd.html
DDDsquad_s13panda is offline   Reply With Quote
Old 01-09-2009, 03:16 PM   #15
guitaraholic
The prob with Viscous are, they don't really hold up to the abuse, and after 100k miles or so, they are pretty much an open dif. Also Helicals work on a completly different concept than 1.5 or 2-way clutch type. The Helical biases the torque to the wheel with the most grip, where the clutch locks the two side together.
Old 01-12-2009, 11:48 AM   #16
guitaraholic
Been doing a little research, and it seems a few people have said that the our R200 differentials will work perfectly with there SC400/Supra. If that is the case, it should work the other way around. I believe they just had to swap out the haftshaft for the Nissan's. If that is the case, you can pick up a helical for about $100-150, and whatever the cost of the halfshafts. Would make for a low cost helical alternative and good OEM quality, and the Supra's are bulletproof (think of the 1000HP ones out there)
Old 01-12-2009, 01:47 PM   #17
GSXRJJordan
That would be very interesting... I say give it a shot
Old 01-12-2009, 02:39 PM   #18
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
If their differentials are so good and so cheap then why are they switching to our expensive ones?
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 01-12-2009, 04:23 PM   #19
guitaraholic
There's more than one reason to change out a diff. From what I've read, the Nissan diffs are a bit shorter, giving an overall lower gear ratio and a little quicker acceleration. Its probably cheaper for someone to get a used diff and shafts than a "custom" diff ratio.
As far as them being crap, I haven't read anywhere about exploding diffs, and supra's come stock with 320hp and a lot of them are over 400 WHP with no probs at all. S2000's diffs, yeah, I would stay away from them. I've heard they won't handle much more than 300HP. Some of the S2000 owners have been switching there diffs out for the one in the Mazda miata/rx7/rx8. Which again, that helical can be had for cheap.
Old 04-26-2009, 09:17 PM   #20
guitaraholic
OK, I know this is an old thread that I started a while back, but got some new INFO. I found out that you the 2007 and up Subaru Legacy GT's use R200 Helical LSD's. Its a 29 spline count. Does anyone have any more info on that. Would be a way to get a good LSD with low mileage and maybe at a nice price
