Old 01-21-2009, 11:50 PM   #1
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
speedo trippen... HELP
Ok ima try to keep it as simple as possible...
My car: S13 coupe w/ Redtop swap stock
Ok i did a search on this and found a few threads on similar problems that im having. My speedometer is not reading. Now recently I had a short and the 2 cables from the clutch pedal switch grounded out and fried those puppies. So I took all the tape of the hardness that comes from the driverside wheel well to the inside behind the pedal and replaced with some new wire. Some how those 2 wires would get on the way when i would start the car and got caught in between the pedal and the floor so that how i got the short. Anyway when that happen my licenses plate lights burnt, pop ups wouldnt come up when i would turn the lights on an soon after that i noticed my speedo not reading anymore. So i did the search and found that there is a fuseable link in the engine bay that goes out i believe its a 25A a brown one . So i pulled it out and noticed it was blowend so i replaced it. After replacing the link including the bulbs for the lic plate the pop ups worked and obviously the lights aswell but speedo still didnt read. I've checked the fuses inside car nothing burn..... The weird thing is that sometimes when i punch it the speedo seems like it wants to work it'll float up and down like if it wants to work. Or sometimes when im driving slow it'll want to read. Everything in the cluster works fine just the speedo. I really dont know what else to check it was working just fine. Any input would help guys.
zylvia213 is offline   Reply With Quote
Old 01-22-2009, 12:07 AM   #2
don_bagz
don_bagz's Avatar
don_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to behold
my speedo does that when my car had low gear oil.. either that, or your pinion is worn out...
don_bagz is offline   Reply With Quote
Old 01-22-2009, 12:12 AM   #3
zylvia213
zylvia213's Avatar
Trader Rating: (36)
what do you mean the pinion...???
Old 01-22-2009, 12:32 AM   #4
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
the pinion on your speed sensor, this same thing happen to me when mine was all grinded and stripped. the red gear in this picture might be worn out soo you need a new one.
kevmeistah21 is offline   Reply With Quote
Old 01-22-2009, 04:01 AM   #5
don_bagz
don_bagz's Avatar
sorry, the speed sensor pinion.. as stated above
Old 01-22-2009, 08:33 AM   #6
zylvia213
zylvia213's Avatar
Trader Rating: (36)
where can i get one and how much are these? would KA tranny pinion work? anything else i wana check first before this pinion. thanks for the input guys.
Old 01-22-2009, 09:12 PM   #7
don_bagz
don_bagz's Avatar
pinions are around 20 bucks the most.. and i heard the only difference between sr and ka are bellhousing.. so it should work
Old 01-23-2009, 12:10 AM   #8
zylvia213
zylvia213's Avatar
Trader Rating: (36)
thanks for the info guys. Its weird cause today out of no where the speedometer started reading fine for a good while and then started trippen again. I'll check it out this weekend see what i find. It's just weird how it just started messing up from one day to the other.
Old 01-23-2009, 11:24 AM   #9
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
lol my hardbody does the same thing, its a 95 and I can usually punch the top right part of the dash and the needle jumps back to life! I have no idea whats wrong with it.....
Otto347 is offline   Reply With Quote
Old 01-23-2009, 12:22 PM   #10
zylvia213
zylvia213's Avatar
Trader Rating: (36)
^^^ can these be true (low gear oil)???? This problem is driving me crazy. I havent tried hitting my dash.... as strong as i am i dont want to end up fucking some other shit up lol
