Old 05-31-2003, 12:50 PM   #1
maccrank
maccrank's Avatar
maccrank is an unknown quantity at this point
check engine light
I just installed my injen intake on monday and by thursday my check engine light in the dashboard went on and is still on. Anyone have any ideas/suggestions ??
maccrank is offline   Reply With Quote
Old 05-31-2003, 05:56 PM   #2
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
If you started the car with thw MAF sensor unplugged, that could cause it. Also, maybe you knocked a plug loose.
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
Old 05-31-2003, 06:59 PM   #3
maccrank
maccrank's Avatar
I started the car the same day I instaled it and the light didn't come on. 3 days afterwards it came on
Old 05-31-2003, 08:47 PM   #4
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Well maybe the code isn't coming from the intake. Did you check the ECU?
thelinja is offline   Reply With Quote
Old 06-02-2003, 08:43 PM   #5
maccrank
maccrank's Avatar
I checked all the plugs they were all connnected. What I don't understand is how come the light lit up 3 days afterwards
Old 06-02-2003, 10:00 PM   #6
019
019's Avatar
019 is an unknown quantity at this point
Send a message via AIM to 019
you should go get the ecu code pulled, so you know what's might be the problem. autozone can do that for you at no charge.
019 is offline   Reply With Quote
Old 06-02-2003, 11:08 PM   #7
hotrodman
hotrodman is an unknown quantity at this point
Just a thought.
Could it be the sensor the goes into the air box? I don't think the injen intakes have that fixed in the adapter. Some people have fabbed them to fit. Does it make your car run any different? Reset your ecu and see what happens, maybe.
Mess with the best, lose like the rest.
hotrodman is offline   Reply With Quote
Old 06-02-2003, 11:16 PM   #8
thelinja
thelinja's Avatar
Dude, just check the ECU yourself. Autozone won't do it.(at least that's what I've learned from my experience) It might be some BS code anyway. For instance, my ECU has thrown two codes since I've had the car, both of the codes were for an auto tranny, and my trans. is a 5 spd. If you don't know how to check the code, click here
Old 06-04-2003, 06:52 PM   #9
maccrank
maccrank's Avatar
thanks for the link thelinja I just checked it the code was 35 EGR temperature sensor
If it doesn't rain tomorrow I'll check it out
