Blue-ish smoke from exhaust
i just wanted some feedback.
its a sohc KA. had a rebuilt, resurfaced head, new valve seals/guides about March 08. also new headgasket. its not blowing a lot of smoke only when im at full throttle around 5.5k-7.5k rpms. not overheating AT ALL. still pulls strong. if i drive normal theres no smoke at all. when it does smoke its kinda blue-ish. im thinking piston rings since the block is at about 190xxx. but what about 02 sensor or fuel mixture running rich. i know it cant be the valve seals or head gasket. also, it doesnt seem to be losing much oil( even though the oil pan is kinda leaking oil) any ideas?
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
He means the rubber rings/gaskets that run along inside the Valve cover. They usually come in a set with a new valve cover gasket. I honestly would say piston rings though. I'm having the same prob, but mine does a quick puff on start off too.
![]() Join Date: Feb 2009
Dont do a compression test. Compression test is for compression rings. Leakdown test would work better. But since you said the head as new guides and seals the only thing i can think of is the tube seals. Ill check around for ya.
![]() Join Date: Dec 2002
spark plug gasket???? um ok...
on a SOHC with what you say "blue smoke... high rpm", it means 1 or 2 things.... piston rings and/or stem seals and since you said you have new stem seals then that leaves only the rings.
No... no one stole my interior... its safely in my garage... ![]() |
