Old 02-13-2009, 01:56 PM   #1
InKfIx2008
InKfIx2008 is an unknown quantity at this point
Send a message via AIM to InKfIx2008 Send a message via Yahoo to InKfIx2008
HELP ME! sr Boost leak????
well alright so my s13 is good when ideling but as soon as I start driving it sputters.. bad. Is this a boost leak? injectors? what? the coil pack seems to be fine as well as the spark plugs....
Please help me out and let me know what you think it could be THANKS!!
InKfIx2008 is offline   Reply With Quote
Old 02-13-2009, 02:09 PM   #2
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
listing all of your modifications would be helpful
codunc is offline   Reply With Quote
Old 02-13-2009, 02:25 PM   #3
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
What do you mean by sputtering? My sr20 was doing something similar. it would ide fine but when i went to accelerate it would sputter and cut in and out and have a shit fit. turned out to be rust in the tank. filters were shit plugged too. check that. make sure it has good fuel pressure too. about 40 psi.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 02-14-2009, 12:13 AM   #4
InKfIx2008
Just a stock SR20DET... everything else is stock.
Old 02-14-2009, 12:23 AM   #5
InKfIx2008
Exactly. thats what its doing. I thought it was either injectors.. well something to do with the fuel system or that it was a boost leak... but Im not sure on how to check that. im taking the injectors out tonight and Im going to soak them in "sea foam" and put a bottle in the tank see if that cleans up the problem. Ill also take a look at my fuel filter. thanks
Old 02-14-2009, 02:07 AM   #6
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
i had a problem like that and it turned out to be a loose coupler.
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 02-14-2009, 02:40 PM   #7
InKfIx2008
Coupler?? where is it located?
Old 02-14-2009, 02:46 PM   #8
soulsynchromachine
soulsynchromachine is an unknown quantity at this point
Your coupler, you know on your intercooler pipe and intercooler. Check to see if there loose or as a slice in them.
soulsynchromachine is offline   Reply With Quote
Old 02-14-2009, 03:13 PM   #9
Banegraphix
Banegraphix's Avatar
Banegraphix is an unknown quantity at this point
check to see if your air intake coupler is loose could be that your MAF isn't reading flow
Banegraphix is offline   Reply With Quote
Old 02-14-2009, 08:33 PM   #10
InKfIx2008
so i have an update. I checked my sparks plugs while it was running, and I unplugged every one. 3 were good when I pulled off the plug the engine would run like shit. the last one I took off the engine didnt change at all. so I went to go buy new spark plugs and I just put them in... nothing changed,still runs like shit. So does this mean that its the PLUG? WIRES? what is it?? and can anybody in San diego help???
Old 02-14-2009, 08:34 PM   #11
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
Mine did the same thing, it was the coil packs.
Couped_up'd is offline   Reply With Quote
Old 02-14-2009, 08:34 PM   #12
InKfIx2008
checked it and everything seems good.
Old 02-14-2009, 08:40 PM   #13
InKfIx2008
where can I buy coil packs??? Would I be able to get them at autozone?
Old 02-14-2009, 09:17 PM   #14
InKfIx2008
nevermind i think I found somebody... well thanks for all the help guys. Ill let you know how it goes with the coil packs
Old 02-16-2009, 01:51 AM   #15
InKfIx2008
wasnt the coil packs... justthe harness... works great now
