problem wiring kill switch
im wiring in a fuel kill switch and its not working. i followed some instructions on someones website, heres the diagram they gave me, i added the bit at the top right:
![]() i wired it to the yellow/black wire coming from the fuel pump. should i ground the middle tab on the switch? any ideas why it wont work? i dont quite understand why the switch is wired to the ground contact and the load side for the power is looped to the ground contact on the relay. |
![]() Join Date: Nov 2006
i dont think that will work. Spilce into the power wire for the relay. ground the switch done. When the switch is flipped on it will allow a complete loop, when flipped off it will break the loop = kill switch.
92 vert converted 5speed and other little things |
#3 | |
thanks, ill fix it tomorrow. |
![]() Join Date: Dec 2002
It's better, cleaner, and safer to cut the signal wire since it's a low current feed, plus it's easy as shit. Find the black/pink from the ECU, cut it half, wire each side to one leg of a SPST switch.
Done. No relay, no fuses, and no extra parts.
i came across that method, is it ok to extend that wire that much though? the reason i wanted to use the relay is so i didnt have to extend the wire all the way to where the switch is.
Doesn't hurt a thing, it's low current. Extending the high current wire would be a problem since there's more resistance, the signal wire though can be as long as you want.
Dont second gusse project rdm it something is safe on what he said. The guy knows what he is talking about.
wel its good to know someone knows what theyre doing, is sure dont haha. but thats why i bought the car...to learn. also that paypal sucks site on his sig is fucking scary! i think i might cancel my account now.
