Old 02-19-2009, 11:25 AM   #1
sicwitit11
sicwitit11's Avatar
sicwitit11 is an unknown quantity at this point
s13 wet floor problem please help!
today i noticed that my windows had alot of moisture on them from the inside. i got into my car and noticed my carpet was completly soaked!. it has been raining alot lately so im guessing i have a pretty bad leak somwere. where would be good place to start lookin? i dont want it 2 start smelling bad or rust away at my floorboards.. thanks guys
sicwitit11 is offline   Reply With Quote
Old 02-19-2009, 11:54 AM   #2
ericcastro
ericcastro's Avatar
Did you drive in the rain at all?
cause it could have came through the floor. Like if you have removed rear seatbelts or something.
Sunroof?
did the sunroof leak?
or the hoses that drain the sunroof through your interior panels behind your seats?
did it come through the firewall area?
Are all the plugs in place.
Is it a convertable and did you leave the top down?
Basically, no one here can help you.
Your question is so broad with no clues, it could be anything.
Your gonna have to do a little investigation yourself.
Old 02-19-2009, 11:56 AM   #3
projectRDM
projectRDM's Avatar
Exactly. There's a hundred places water can intrude into the cabin, without knowing the model, options, modifications, etc. we're all guessing in the dark.
FORMERLY R240NA
Old 02-19-2009, 11:59 AM   #4
SBCsx
SBCsx's Avatar
SBCsx has a spectacular aura aboutSBCsx has a spectacular aura aboutSBCsx has a spectacular aura aboutSBCsx has a spectacular aura aboutSBCsx has a spectacular aura aboutSBCsx has a spectacular aura about
your trunk? window molding?
SBCsx is offline   Reply With Quote
Old 02-26-2009, 11:39 PM   #5
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
I had a leak that turned out to be the rubber around the tail lights. water runs down the channels for the hatch and gets between the tail light housing and the body. silicone fixed it right up.
Tom25666 is offline   Reply With Quote
Old 02-26-2009, 11:46 PM   #6
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
to look for a leak just have someone hose water around the windows and moldings and look inside for drips..
Slammed Assassin is offline   Reply With Quote
Old 02-26-2009, 11:56 PM   #7
cc4usmc
cc4usmc's Avatar
Or you can get one of those bug bombs and set it off inside your car. To find the leak, just get around your car and sniff. When you start coughing, you've found your leak.
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 02-27-2009, 12:09 AM   #8
Cloud9
Cloud9's Avatar
Cloud9 is making a name for him/her selfCloud9 is making a name for him/her self
I'm going to say your heater core is leaking, shot in the dark. Replace it and see if it fix's the wet problem.
FOR SALE
Cloud9 is offline   Reply With Quote
Old 02-27-2009, 12:36 AM   #9
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
i have a coupe.
check your windshield.thats where i get all my water from..
and it sucks.
HS13KLS is offline   Reply With Quote
Old 02-27-2009, 02:49 AM   #10
Spencer dougherty
Trader Rating: (65)
Feedback Score: 65 reviews
its your heater core!!
Old 02-27-2009, 03:16 AM   #11
projectRDM
projectRDM's Avatar
And you know this how? Heater core leaks coolant, not plain water. It's highly unlikely that the OP doesn't know the difference between the two.
FORMERLY R240NA
Old 02-27-2009, 07:50 AM   #12
1fastser
1fastser is an unknown quantity at this point
What you're gonna have to do is take off a lot of interior panels and get up in your dash to look...while you're hosing your car off with water (or someone else).
If the carpet was mostly wet in the front of the car, start with the corners of the windshield...good luck.
1fastser is offline   Reply With Quote
Old 02-27-2009, 07:54 AM   #13
g6civcx
g6civcx's Avatar
Since it could be anything, I'm going to guess the taillights leaking into the interior.
Old 02-27-2009, 09:38 AM   #14
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
im gonna vote for.... leaving the windows down
or heater core... since the OP did say the carpet was soaked, and to me that means a lot of fluid... more than could have got in from it rainning
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 02-27-2009, 03:59 PM   #15
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
Sit in the car, and have someone hose the car down, and watch for leaks.
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 02-27-2009, 04:14 PM   #16
Cloud9
Cloud9's Avatar
Drive it through a car wash, one of those high pressure ones!
FOR SALE
Old 02-27-2009, 07:55 PM   #17
projectRDM
projectRDM's Avatar
All of the firewall grommets are culprits too, especially in the fender wells where the hood cable and ASCD harness go through. My engine harness is out right now and water trickles in through that big ass hole every time it rains.
FORMERLY R240NA
Old 02-27-2009, 08:40 PM   #18
yurisfriendevan
yurisfriendevan's Avatar
yurisfriendevan is an unknown quantity at this point
If it was the heater core you would be able to smell the coolant.
yurisfriendevan is offline   Reply With Quote
Old 02-27-2009, 09:00 PM   #19
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
While we're somewhat in the topic, is it typical for the seat brackets and other steel pieces(like the area under the shift knob for example) in the cabin to have some surface rust?
Almost there.
Mangudai is offline   Reply With Quote
Old 02-28-2009, 02:21 AM   #20
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
i think your flux capacitor is leaking, or maybe even your blinker fluid overflow resavour
supreme_1 is offline   Reply With Quote
Old 02-28-2009, 04:22 AM   #21
projectRDM
projectRDM's Avatar
Some light surface corrosion is typical since they're not coated with anything. The dash crossbar and rear seat brackets do it too, along with the pedal brackets. I powdercoated all my parts while the interior was out because it bothered me but a coat of rustoleum works fine.
FORMERLY R240NA
Old 02-28-2009, 01:03 PM   #22
Mangudai
Mangudai's Avatar
OK that's what originally had me wondering about this. I'll look into powder coating then as well. Thanks.
Almost there.
carpet, moisture, rain problems, water, windows
