Old 03-06-2009, 08:21 AM   #1
projectRDM
projectRDM's Avatar
Originally Posted by MrChow View Post
the alt is ground to the engine. just ground ur engine better.
Not quite, there's a separate ground wire as well. The bolt is an M5x.08 thread, it's tiny, what I usually do is remove one of the M5 nuts that hold the case together and bolt it there.
FORMERLY R240NA
Old 03-06-2009, 08:29 AM   #2
Sideways~S14
Sideways~S14's Avatar
Sideways~S14 is making a name for him/her selfSideways~S14 is making a name for him/her self
Send a message via AIM to Sideways~S14
I love you long time!
Sideways~S14 is offline   Reply With Quote
Old 03-06-2009, 11:47 AM   #3
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Just curious I know of the separate ground. I was redoing all my ground and I thought just having good grounds on the engine would work just fine. Now if I redid my alt ground would that help a bit more or not Russ??
Sorry if I didn't word that correctly.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 03-06-2009, 12:46 PM   #4
projectRDM
projectRDM's Avatar
An electrical ground is just as good, if not better, than a mechanical ground. I always replace the OE wire with a larger piece (4ga) and run it shorter, usually right to the frame rail.
FORMERLY R240NA
Old 03-06-2009, 03:05 PM   #5
MrChow
MrChow's Avatar
Well I have 0ga wire for my grounds for the battery and engine. I just have 8ga stuff left. I guess I'll throw one of theses on.
Old 03-06-2009, 07:52 PM   #6
projectRDM
projectRDM's Avatar
8ga is fine, the OE ground is 12ga. Anything is better than that. Keep it really short, and scrape the paint away before bolting it down.
FORMERLY R240NA
