Old 06-16-2003, 05:21 PM   #1
werm
werm's Avatar
werm is an unknown quantity at this point
gauges
You know that little cubby right below the stereo? Do they make like oil pressure gauges ect to fit in there instead? Someone has probably wanted to put it there besides me!
werm is offline   Reply With Quote
Old 06-16-2003, 08:11 PM   #2
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
I haven't come across any gauge panels specifically made for that space, but I'm new to the scene.
I do know that cubby below the stereo is a "din" tall which is I believe just over 2" in height. I know that there are gauges out there that are 2" so with a bit of DIY style and ingenuity you could probably make one for yourself.
Granted this is all moot if they're already out there you could always google for gauge panels meant to replace car stereos.
radhaz is offline   Reply With Quote
Old 06-16-2003, 09:31 PM   #3
Rocketman
Rocketman is an unknown quantity at this point
A company called Omori Makes a DIN size guage panel pod. I have seen these installed in many nissan cars. (primarily front wheel drivers).
They work great and IIRC hold three 45 or 52mm guages
Check out:
http://www.omori-na.com/catalog/acce...ccessories.htm
Rick
Rocketman is offline   Reply With Quote
Old 06-17-2003, 06:17 AM   #4
radhaz
radhaz's Avatar
I figured someone out there had to make one. I'm curious as to how hard that would be to DIY though.
Old 06-17-2003, 08:14 AM   #5
Rocketman
I don't think it would be to hard to DIY, but its also nice that those are angled towards the driver.
Less glare etc.
It would be a little more difficult to DIY and have it angled like that.
Just out of curiousity, what kinda guages you using?
Saw some rather interesting ones the other day. Autometer is now making a full 270° sweep electric guage series. Look pretty nice, but i'm not to sure of the quality.
Rick
Old 06-17-2003, 08:59 AM   #6
S14Speed997
S14Speed997's Avatar
S14Speed997 is an unknown quantity at this point
Check on Ebay under " 240sx white gauges"..you will see exactly what you are looking for...over the past couple weeks, the same guy has been selling those...Eric
S14Speed997 is offline   Reply With Quote
Old 06-17-2003, 09:16 AM   #7
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
Blitz used to make one that went there. it only held 46mm guages though. (held three of them) I've got one at the house Im not using. been tinkering with the idea of dremeling it out to put guages 52mm guages in it. dunno.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 06-18-2003, 05:01 AM   #8
quicknismo
quicknismo is an unknown quantity at this point
I made a custom gauge panel under the stereo with an Air/Fuel stoich meter and a fuel pressure meter. Both are the new Cobalt series from Autometer.
quicknismo is offline   Reply With Quote
Old 06-18-2003, 11:38 AM   #9
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
If getting the parts from Omori is too much of a hassle. You could go by a Menards or something and get some plastic or something and make the bracket yourself. Using a quote from a good friend of mine, 'L.B.R.'. If you make the part yourself, you'll learn a little more and have some extra pride in your car.
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 06-18-2003, 01:22 PM   #10
SpeedRacer1
SpeedRacer1 is an unknown quantity at this point
You can make your own really easily with any flat material. Just get something about 1/8 or 1/16th inches thick and cut out 2 46mm or 3 52mm holes. Then voila, paint it or do whatever you want.
SpeedRacer1 is offline   Reply With Quote
Old 06-19-2003, 03:47 AM   #11
mixedwell
mixedwell is an unknown quantity at this point
Send a message via AIM to mixedwell
what kind og guages are those speed racer? i want them now!!! ahaha hholla
-mixedwell
silvia... my love ::
mixedwell is offline   Reply With Quote
Old 06-19-2003, 10:05 AM   #12
SpeedRacer1
Blitz ID series in blue 52mm.
http://www.blitz-na.com/Blitz_M_Gauge_ID.htm
Old 06-19-2003, 12:40 PM   #13
KOUKI KA-T
KOUKI KA-T's Avatar
KOUKI KA-T is on a distinguished road
HKS makes a DIN panel that houses 3 46mm gauges, very nice looking but be prepared as HKS gauges are very pricey. I myself made a custom DIN panel from plexi glass that houses 2 Greddy 52mm gauges. Took me only 2 hours max and it is perfect. I did end up selling the gauges and deciding to go with the HKS unit as i wanted all 3 of my gauges under the head unit. But if you're only using 2 gauges make your own panel, it's easy.
KOUKI KA-T is offline   Reply With Quote
Old 06-20-2003, 02:57 AM   #14
SpeedRacer1
The only problem with the HKS 3 gauge 46mm unit is that most of their 46mm gauges are discontinued. Also the limited supplies they have left are mix and match so you may have to settle for gauges of different colors.
Old 06-22-2003, 01:55 PM   #15
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Yep, with a thick sheet of plexi and some time.. you can fabricate your own clean gauge bezel. Here is what mine looks like:
"Now boarding, flight S13... please be seated and fasten your harnesses..."
old_s13 is offline   Reply With Quote
Old 06-22-2003, 05:42 PM   #16
ghostchild316
ghostchild316's Avatar
ghostchild316 is an unknown quantity at this point
Thats pretty freakin nice Mike!
S13 Fastback KA24DET - IG: @alonso240
AWS D17.1 Certified TIG welderIG
ghostchild316 is offline   Reply With Quote
Old 06-23-2003, 01:05 AM   #17
Warwick5s
Warwick5s's Avatar
Warwick5s is an unknown quantity at this point
HOW?!?!
guh, that's beautiful!
Warwick5s is offline   Reply With Quote
Old 06-23-2003, 06:42 AM   #18
Steeles
Steeles's Avatar
ooh good stuff Mike... I dont think I['d ever seen your interior before. how long did it take to replace all that to match?!?! I'd thought of doing something like that once I get all my guages in. looks super pimp
