Old 03-26-2009, 11:54 AM   #1
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
Swap to non hicas
Going to be getting all the parts next week and i wanted to know if this was a job that i should take it to someone or can do it myself?
Also how long would it take?
xpinoyxmk is offline   Reply With Quote
Old 03-26-2009, 11:55 AM   #2
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
It depends how fast you work.
Are you getting the subframe, etc. from a HICAS car and swapping it?
Or putting on one of those HICAS cancelling bar things?
awesomenick is offline   Reply With Quote
Old 03-26-2009, 01:26 PM   #3
xpinoyxmk
Taking out the super hicas and replacing all the parts with non hicas parts.
Old 03-26-2009, 02:25 PM   #4
projectRDM
projectRDM's Avatar
By using a non HICAS subframe? You left out actually answering the question, which kind of defeats the purpose of you asking in the first place.
Just swapping the subframe complete and removing the lines/pump is a good 2-3 hour job. Easy with common hand tools, helpful if you have air.
FORMERLY R240NA
Old 03-26-2009, 02:54 PM   #5
sup3r
sup3r's Avatar
sup3r is an unknown quantity at this point
Send a message via AIM to sup3r
I'm getting ready to do this swap as well. as far as I know the only parts you need are:
-Rear NON-Hicas rear subframe
-Rear toe control arms
What I dont know is how to deal with the Hicas pump. Does the pump use power steering fluid? What do i have to do to delete the pump, plug some hoses or something? Do I need a non hicas power steering pump/brake booster?
sup3r is offline   Reply With Quote
Old 03-26-2009, 03:26 PM   #6
projectRDM
projectRDM's Avatar
You need the uprights too. There's a ball joint pressed in for the toe arm instead of a bushing.
The pump does not use power steering fluid. Please don't assume that. ATF only. Power steering fluid is NOT TO BE USED in any Nissan vehicle, anywhere. Deleting the pump will eliminate your power steering altogether, if that's your plan then do it. Otherwise you either disassemble the HICAS pump and remove the vains in the secondary portion, or buy and install a non HICAS pump and bracket.
The brake booster is the same as an auto unit, you don't have to swap it unless you're bored.
FORMERLY R240NA
Old 03-26-2009, 06:12 PM   #7
xpinoyxmk
I have:
-NH complete subframe
-NH ps pump
-NH ps resivoir
-NH ps cooler lines
I was told that all i needed. So im going to be getting all the parts together next week. May ill take some pictures and make a DIY.
