Old 04-18-2009, 04:16 PM   #1
slidewaysmn
slidewaysmn's Avatar
slidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really nice
SR not starting. Redtop in s14. No priming injector pulse.
I recently swapped a redtop in my s14, and im not getting a primer pulse to the injectors. If i start it with starter fluid it will start, and idle, but there is no pulse when trying to start. There is no voltage drop from the battery to the injector also. Any help? I've been dealing with this for far to long....haha. Thanks in advance :]
'95 Zenki
'85 Cressida
slidewaysmn is offline   Reply With Quote
Old 04-18-2009, 07:01 PM   #2
slidewaysmn
Update: Not running over 2500 rpm...sounds like launch control. Does the sr ecu have a "limp mode", what can cause it? It's also running extremely rich. black smoke rich. Any help...please
'95 Zenki
'85 Cressida
Old 04-18-2009, 07:59 PM   #3
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
not running over 2500rpm... isn't that mafs related? check your wiring.
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 04-19-2009, 10:37 AM   #4
slidewaysmn
I believe you are correct. I'm going out to check my grounds in a bit.. Any help on the priming pulse yet?...anyone else have this problem?
'95 Zenki
'85 Cressida
Old 04-19-2009, 09:53 PM   #5
slidewaysmn
Bump...the maf isn't grounding...the ground goes to the ecu, and i believe the ecu grounds it... jumped the ground to the strut tower and still nothing. Any help...Pppplease.
'95 Zenki
'85 Cressida
Old 04-20-2009, 03:38 PM   #6
slidewaysmn
F me in the A...bump. I'm thinking its the ecu, because it's also running super rich, and still no start.
'95 Zenki
'85 Cressida
