Old 04-20-2009, 07:02 AM   #1
OBEEWON
OBEEWON's Avatar
Fender Harness/Full Lock
Im sure everyone has dealt with the fender harness at some point. The issue Im having seems to affect either S14's only or people running man sized wheels and offsets in the front.
I have relocated my harness to the point there is no chance of it getting eaten by the top of my tire. But at full lock I rub the harness where it enters the firewall to go into the cabin. What have people done to fix this issue? The only thing I can think of is bolting/welding a plate over the entrace.
Thoughts/solutions?
Old 04-20-2009, 11:22 AM   #2
PoorMans180SX
PoorMans180SX's Avatar
Run it through the engine bay.
It's not exactly easy, but it works.
Old 04-20-2009, 11:33 AM   #3
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
please come up with another solution than that lol
relocating through engine bay seems like pretty gay ass tedious work...
i like the plate idea
by the way, to the OP.
what is your caster at? idk what your setup is so im not sure if u just have stock tension rods and ur wheel is super far back in ur wheel well. or you have the caster exactly where you like it haha
nieko is offline   Reply With Quote
Old 04-20-2009, 12:19 PM   #4
projectRDM
projectRDM's Avatar
I've seen the plate idea. Easy and quick.
FORMERLY R240NA
Old 04-20-2009, 12:43 PM   #5
qt_240
qt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really nice
I did the plate thing.. its easy, fast, and it works..
Dorimonster.blogspot.com
qt_240 is offline   Reply With Quote
Old 04-20-2009, 12:44 PM   #6
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
Any links to this plate method? (s13)
Do you weld the plate or how does it work, because I actually have exposed my wires already, and I haven't figured out how I want to fix the issue.
lightsource is offline   Reply With Quote
Old 04-20-2009, 12:50 PM   #7
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
You can also completely relocate the fusebox to somewhere inside the cabin, however it's even more tedious work. Either way you're looking at some work. Never though about the plate idea but i guess that would work too.
NiSilS14 is offline   Reply With Quote
Old 04-20-2009, 01:05 PM   #8
OBEEWON
OBEEWON's Avatar
Im not sure what my castor is but I went pretty crazy with it to see if I could miss the harness.
The engine bay method solves nothing as thats not where the wheel is rubbing, and relocating the fuse box wont help as wirse to the lights and etc must come through. You could relocate the harness to come through a higher point but that would be stupid silly work.
You guys with the plates. Do you tack them on or rivet or what?
Old 04-20-2009, 01:22 PM   #9
r6_240sx
r6_240sx's Avatar
r6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfectionr6_240sx is close to perfection
Relocating to engine bay actually does solve problem because there's no more fender harness in the wheel well area. Tedious, but it works.
Edit - Maybe this will help you:
http://zilvia.net/f/1162200-post34.html
As for the plate method just get some sheet metal and screws and lift up the harness and cover it with sheet metal.
Here's the one from BOSS (discontinued):
Let the tire rub the metal all day, no prob. In your case you'll have to cover the back side where the grommet is.
r6_240sx is offline   Reply With Quote
Old 04-20-2009, 01:42 PM   #10
nieko
i was going to call you an idiot until i read the ending of your post haha
yea, metal plate on that back part, probably what im going to do
Old 04-20-2009, 02:25 PM   #11
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
I want to see some pics of peoples plates in the back.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 04-20-2009, 03:15 PM   #12
SoSideways
SoSideways's Avatar
Yes, the grommet is where everyone is talking about rubbing.
I had 235/40/17s on my wheels, and at full lock to the left, it would rub the grommet and the part of the harness where it's coming out of the grommet.
Even with a lot of caster it didn't help, because at a point, you run out of caster adjustment both from the LCA contacting the mounting bracket (unless you have a rod end type adjuster there) or your wheel will hit the front wheel well hardcore, requiring a wheel tub.
Even then, you're going to run into problem with excessive positive camber on the outside front wheel at full lock during a drift, and you might as well be riding on sidewalls or the lip of the rims then. You'll probably need like 7 or 8 degrees of static negative camber to correct that situation...
Anyway, I want to see some of the grommets that people have put on their cars, along with their alignment/wheel/tire specs if they can remember, please!
Old 04-20-2009, 03:43 PM   #13
projectRDM
projectRDM's Avatar
I don't understand why people need pictures of this. Imagine a piece of steel, tin, anything cut out into a plate. Usually it's bought in sheets anyway, so imagine it a little smaller. Now look at where the harness is exposed to the tire exiting the firewall. Put the plate over it, blocking the tire from contacting the harness. Secure with welds, rivets, screws, zipties, anything to just hold it still. The tire will rub against it and being smooth it won't interfere with either the tire or the harness. It's really not that complicated guys. You can even get creative and buy a piece of pipe or tubing, cut it in half length wise and make an actual sheath for the harness, welding it to a plate. There's a million ways to do it, none of them better than the other if they all work. Get creative.
FORMERLY R240NA
Old 04-20-2009, 03:49 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Umm...when and if you decide to re-route the wiring into the engine bay, you dont go thru the same spot inside the wheel well. You plug that spot up and drill a new hole for the wiring around the same spot as the engine wiring harness.
CLICK HERE!!!
Old 04-20-2009, 04:33 PM   #15
Om1kron
Om1kron's Avatar
plate.
Wayne Edwards
https://om1kron.blogspot.com
Old 04-20-2009, 04:39 PM   #16
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
relocate to the engine bay.
never worry again.
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 04-20-2009, 04:56 PM   #17
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
remove all of the plactic bends in the harness, this should give you about 1" extra of slack. Also cut out part of the triangulated metal under the fender. You can then tuck the harness up there and there is now way possible for it to rub. Plus you won't have to look at the ugly ass harness running through your engine bay. The pic below is about 75% done, I was able to trim out more and get the harness up a little more than in the pic. Good luck.
khilgers is offline   Reply With Quote
Old 04-20-2009, 05:24 PM   #18
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
I went the tedious work of relocating to the engine bay. Don't forget your still going to have to make sure you cover all the exposed wire individually with electrical tape or something, or else you can still run into trouble with it grounding out.
Well if anyone who has done this or is going to do this (plate idea) make sure you take some pics and post them up.
Good luck with whatevar you do...
Maiku240sxS14 is offline   Reply With Quote
Old 04-20-2009, 05:59 PM   #19
sultan
sultan's Avatar
sultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enough
i screwed an old license plate in there to block where it comes out the firewall. little too big but whatever, i couldn't find my old motorcycle plate.
sultan is offline   Reply With Quote
Old 04-21-2009, 11:45 AM   #20
projectRDM
projectRDM's Avatar
If your harness needs to be taped to prevent grounding out, you have a serious problem. The wiring is all insulated.
FORMERLY R240NA
Old 04-21-2009, 01:48 PM   #21
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
I find the drivers side makes contact more then the pass. side
Chrischeezer is offline   Reply With Quote
Old 04-21-2009, 01:52 PM   #22
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Cold import nights.
Haha.
Old 04-21-2009, 01:56 PM   #23
GSXRJJordan
GSXRJJordan's Avatar
I run 18x10 +0, and was rubbing the front of the fender well and the 'seam' in the back even with 17x8.5's.
The problem is not the grommet itself, it's right above the grommet where the wiring rubs - I relocated my fuse box inside, so I had far less wires to worry about than most, but I ran the wires directly over from the stock grommet into the engine bay, along the frame rail, and up to the rad support - problem solved. Unfortunately, I don't have any pics of it where it hits the firewall.
Edit: Matej that looks like doo doo (but works).
Old 04-21-2009, 02:12 PM   #24
Maiku240sxS14
Trader Rating: (37)
What I meant was...if the wires were already exposed from the rubbing against the tire, you will still need to tape/cover the exposed wires than just putting a plate on and calling it a day....
Old 04-21-2009, 02:40 PM   #25
ryangreg
ryangreg can only hope to improve
I cut, and individually ran every wire through that triangular hole into the engine bay one by one keeping the harness flattened at this point and running through a large p-clip, then sautered back together in the bay. It took forever fuck yea. Still going to add a plate, but it will be tucked back at this point.
ryangreg is offline   Reply With Quote
Old 04-21-2009, 02:48 PM   #26
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
love this thread, going to use a plate just like stated above. Done a tuck before but after thsi weekends event of blown fuses and exposed wires i need to get a smaller series tire and a plate.
Dustxking is offline   Reply With Quote
Old 04-21-2009, 03:08 PM   #27
smelly240
smelly240's Avatar
u guys are all wierd.
his harness gets hit AT THE BACK - by the door.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 04-21-2009, 03:47 PM   #28
GSXRJJordan
Yes, that's where the "running through the engine bay" solves the problem - instead of running "up" the firewall, to where it rubs the tire, you run the wires "in" to the engine bay, below where the tire rubs.
I might have to go down and take a pic of my setup.
Old 04-21-2009, 04:30 PM   #29
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
I just did this on my car today and i went with the same method. I notched the triangular part then pulled it up the bent the rest to hold the harness up as well as zipties.
jorge1190 is offline   Reply With Quote
Old 04-21-2009, 06:36 PM   #30
projectRDM
projectRDM's Avatar
I cut the triangle out on my car, gives more room to pull it tight.
FORMERLY R240NA
