Old 07-03-2003, 04:05 PM   #1
Johny5
Johny5's Avatar
q45 brakes
Simple, down to the point. Went to Autozone, priced out two front q45 calipers for $100. They fit on stock lines, perfect. Fit inside the 16" wheels perfect. Need to know, 300zx tt rotors, 300zx na rotors, q45 rotors. And which years of the vehicle? I priced out 97 q45 brakes, wondering if I should get the 90-96 fronts instead? Please dont call me stupid n00b, the website with all the info on the swap is down. Thanks for your time.
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 07-03-2003, 04:29 PM   #2
red98s14
red98s14 is an unknown quantity at this point
Get the '90 - '96 calipers. I think the '97 are different.
You need Q rotors. They're 28 mm thick.
red98s14 is offline   Reply With Quote
Old 07-03-2003, 04:30 PM   #3
Johny5
Johny5's Avatar
Hey thanks a bunch man for the quick response. Might be ordering these things tommorrow, im giddy like a school girl.
Old 07-03-2003, 05:02 PM   #4
Warwick5s
Warwick5s's Avatar
Warwick5s is an unknown quantity at this point
how much bigger are these than stock?
Warwick5s is offline   Reply With Quote
Old 07-03-2003, 06:03 PM   #5
Jim96SC2
Jim96SC2 is an unknown quantity at this point
Send a message via AIM to Jim96SC2
NEED PICTURE COMPARISONS!
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter.
Jim96SC2 is offline   Reply With Quote
Old 07-03-2003, 06:05 PM   #6
Roly
Nuclear
Roly is an unknown quantity at this point
I got 95 Q calipers.. they're 2 piston. The rotors are coming from a 95 model from irotors.net for $150 slotted, plated, and re-drilled for 4-lug. The rotor is an 11" rotor
RACECAR spelled backwards still spells RACECAR
Roly is offline   Reply With Quote
Old 07-03-2003, 09:53 PM   #7
Warwick5s
Warwick5s's Avatar
woot, this sounds like a good upgrade for those of us who don't have a bunch of bling
and i found a nice writeup website:
http://www.cautioncreativity.com/briand/Q45%20Brake.htm
Old 07-03-2003, 10:46 PM   #8
Anubis
Anubis's Avatar
Anubis is an unknown quantity at this point
Send a message via AIM to Anubis
Yeah i was planning this for my old s14, looks like i'll be doing it on my newer one.
Where can you get aftermarket Q45 rotors from?
Anubis is offline   Reply With Quote
Old 07-04-2003, 03:49 AM   #9
Roly
Nuclear
Originally posted by Roly
The rotors are coming from a 95 Q45 model from irotors.net for $150 slotted, plated, and re-drilled for 4-lug. The rotor is an 11" rotor
Old 07-04-2003, 08:15 AM   #10
orion::S14
orion::S14's Avatar
Hey, that's my site. Cool.
Been running these for +3 years with no complaints. Great and cheap.
I'm running 'Powerslot' slotted rotors, got 'em for $95 each from NOPI of all places...
Later - Brian
Old 07-04-2003, 09:41 AM   #11
Johny5
Johny5's Avatar
They got slotted rotors on ebay right now for $120 under buy it now. But I'll take the side-by-side with the calipers if anyone wants them, I'll be purchasing them this week hopefully.
Old 07-04-2003, 10:58 AM   #12
red98s14
I've had the Q calipers on my S14 for over a year. They work very well. I've had no fade during lapping days, which I did with the stock brakes.
I'd recommend changing to braided steel lines at the same time. Really helps the feel.
Old 07-04-2003, 03:31 PM   #13
Johny5
Johny5's Avatar
Alright, checked out Autozone, got rotors going for $34.99 and calipers going for $50.99 and they're gonna take my s14s in as core, kick ***. Too bad I can't afford the lines, but I am however getting Axxis Metalmasters, gotta splurge somewhere in the process.
Old 07-05-2003, 10:09 AM   #14
Bill Roberts
Bill Roberts is an unknown quantity at this point
Stupid question. Would they fit an S-13? If so I would go 5 bolt in a hurry. Just wondering if the calipers would bolt up. Seems like they would not..any ideas?
Bill Roberts is offline   Reply With Quote
Old 07-05-2003, 04:02 PM   #15
Johny5
Johny5's Avatar
How could they not if you converted to s14 5bolt , might wanna double check on the hookups on the lines though. Other than that I don't see why it wouldn't work. Oh, that and make sure you got some 16" dubzzzzz just to make sure they clear, with 15s its probably a hit or miss thing.
Old 07-05-2003, 04:53 PM   #16
Bill Roberts
I think I will go down to the 'zone and see if they will let me take a rotor out to the car, see if the oem alloys and the rotor will work.
Man...the q45 brake deal seems like the way to go....my factory brakes just don't cut it above 90MPH...and I do the track when I can of course.
I go through rotors like two for every 8 tanks of gas..I just burn them up..(on the track, I have been know to go through the complete front brakes in 5 sessions)
I saw an 840 BMW and those rotors are to die for...MaSsIvE
http://www.performancerotors.com/840.shtml
Old 07-05-2003, 06:13 PM   #17
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Originally posted by Bill Roberts
Stupid question
Bill, that was a little mean dontcha think.
As for the brake swap the link posted above would be of greta service in your quest for knowledge.
Forum discussion #1
Thread discussion #2
The tt 300zx swap would be better for a little more. Any reason in particular why not?
zero.counter is offline   Reply With Quote
Old 07-06-2003, 09:42 AM   #18
krakadil
krakadil's Avatar
krakadil is an unknown quantity at this point
I have just completed a 26mm aluminum z-brake swap on my '93 S13. The stock rims cleared by about 1mm to spare with NO spacers. If you are ruling out the z brakes just because of clearance issues, don't. I got 1990 N/A zx aluminum calipers from AutoZone for $150+core for both of them, cross drilled rotors, drilled to 4-lug for $100 each from PDM, and custom steel braded lines for z-brake swap for $100/pair from PDM. Everything bolted up just fine and cleared the stock 7-spoke aluminum wheels without a problem.
Pics
krakadil is offline   Reply With Quote
Old 07-06-2003, 11:23 AM   #19
Jsquared
Jsquared's Avatar
Jsquared is an unknown quantity at this point
yeah so that's ~$350 for 26mm Z brakes vs. ~$200 for Q45 brakes. and i still don't like the idea of just getting bigass front brakes without addressing the rears. Q45 brakes seem like they'd match up with stock S13 rear brakes better...
which brings me to my question: how is the brake balance on Q45 fronts with stock S13 rear? would i still need a MC or a proportioning valve or something?
1992 SR coupe, ~11psi
a.k.a. "Zip-Tie"
www.carolinanissans.com
Jsquared is offline   Reply With Quote
Old 07-06-2003, 11:52 AM   #20
misnomer
misnomer's Avatar
What about clearance? These rotors are wider than the z32 26mm. Anybody use them with seven spoke alloys?
Old 07-06-2003, 07:22 PM   #21
clean
clean is an unknown quantity at this point
Send a message via AIM to clean
is that only for 5 lug or could i just get the rotors redrilled?
clean is offline   Reply With Quote
Old 07-06-2003, 09:25 PM   #22
Jsquared
Jsquared's Avatar
I remember someone saying you can get blank rotors and have someone drill them, but I forget where, haven't been paying attention to brake threads recently need LSD first
a.k.a. "Zip-Tie"
Old 07-07-2003, 09:59 AM   #23
orion::S14
orion::S14's Avatar
The rotor width doesn't add anything tot he clearnace issue - It's the caliper design that makes clearnace bad with Z brakes- They have 2 piston on the outside of the rotor, as opposed to only one on the inboard side of the OEM brakes, and 2 on the inboard of the Q45. this means that MUCH less caliper sticks out from the rotor.
And the balance (brake bias) is about the same as the Z brakes - Remember, the Z weighed 3300lbs, and the Q45 weighed 4100 - The Q brakes are in no way weak as compared to the Z brakes. I'd even wager they would not be outperformed given the same pads...
FYI - I run Z32 rears with my Q45 fronts (driven by an auto S14 M/C which is 15/16"), and love the feel, although it still locks the fronts WAY before the rears...
Later - Brian
Old 07-07-2003, 11:22 AM   #24
clean
so when buying wheels, what would i need to take into account for the size or the amount of the q45 caliper to clear the wheel. right now i have tein coilovers and my brakes are the stock ones obviously, and it being an 89, they are very tired and rusted so i figured the q45 is a cheaper alternative to the z32. i would just get new rear stcok 240 brakes and calipers along w/ the q45 front. i know that its not the offset, but the wheel design but i cant find any wheels that are w/in my budget and will clear my coilovers and upgraded brakes. i wanted kosei's but they dont make the +27 anymore and i really dont want to have spacers for the wheels. gramlights are looking good but i only like the pro's and those are not w/in my budget. my budget was $1200 w. tires and i want yoko es100's for rubber.maybe it would be easyer not upgrading my brakes and just getting new stock rotors and refurbished calipers. does anyone have opinions to my questions?
Old 07-07-2003, 11:27 AM   #25
AKADriver
AKADriver's Avatar
Q45 caliper/spoke clearance is the same as stock. They should fit behind any 15" or larger wheel.
As for the need for a brake upgrade, ask yourself why.
If you're not stopping fast and short enough, and you're not locking up the tires, then your brake system needs immediate maintenance. Replace the pads, flush the fluid, and replace or resurface the rotors.
If you're experiencing fade, try better pads and a high-temperature fluid first.
AKADriver is online now   Reply With Quote
Old 07-07-2003, 06:56 PM   #26
S13CRAVE
S13CRAVE is an unknown quantity at this point
Send a message via AIM to S13CRAVE
will they fit behind the stock s13 steelies? i am really gonna need a brake upgrade once my CA is fired up
S13CRAVE is offline   Reply With Quote
Old 07-07-2003, 07:14 PM   #27
Bill Roberts
Samn question here too. If they will fit behind S-13 teardrops without a spacer, I am definitly in.
My Stock brakes, almost new, witb SS lines are inadaquate. The MS is also new. Just not enough power when good and hot. After the 5th or 6th full brake down on the track from the century mark and going into turns...they are ineffective. Rotors too small, not enough clamping power and too much heat. At night they are red hot during a session. Stock rears are more than good enough for my style of flogging. Even with some rear wheel lockups, no fade and no excessive temperature. I am considering 840i BMW brakes if the Q's will not fit behind the rim...and a lot of modification to the mounts.
Old 07-07-2003, 10:37 PM   #28
AKADriver
AKADriver's Avatar
Yes, they'll fit behind steelies or teardrops. Any 15"+ wheel...
Old 07-07-2003, 10:42 PM   #29
Bill Roberts
Yes!
Then I finally know what my next upgrade shall be.
...Been looking around for something meaningful to do.
My Brakes suck above 100MPH on a large rally track.
Now I am excited. 2 weeks out and a full report and pictures Yee haw!!
Old 07-08-2003, 03:25 AM   #30
Johny5
Johny5's Avatar
I'm with Bill, just waiting for a paycheck on friday so I can order these damn things. Still antsy like a school girl.
