Old 05-16-2009, 06:24 PM   #1
Z33TT
Z33TT's Avatar
Z33TT is an unknown quantity at this point
S14 starter issue
Hey I recently put my car back together after having it sit with no motor for 4 years.
I put a stock KA in it and for some reason the starter wont turn, I don't even hear a click when I turn the key. I thought it might be the starter so I had it tested and its fine. I then thought it might be the starter relay but i can't find any starter relays in the fuse box. Can some one please help me out. Has this happened to others?
Thanks
Josh
'03 Silverstone Track
Work Equip 01, Greddy TT,SVRTechnologies WG dumps, Crawford plenum,
Borla True Dual, Kinetix Testpipes, JWT LWF,UTEC, SP Water/Meth Injection, 7.3psi
'95 Aspen White 240SX
Stock
Z33TT is offline   Reply With Quote
Old 05-16-2009, 06:31 PM   #2
TRU_DAH-V
TRU_DAH-V's Avatar
TRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfection
did you check if your battery still has a charge?
http://zilvia.net/f/avatars/tru_dah-v.gif?type=sigpic&dateline=1234268839
TRU_DAH-V is offline   Reply With Quote
Old 05-16-2009, 06:46 PM   #3
Z33TT
Z33TT's Avatar
I found the starter relay in the interior fuse box and changed it so that isnt the problem I also checked the starter signal fuse and it isnt blown.
That else could it be?
Stock
Old 05-16-2009, 06:47 PM   #4
Z33TT
Z33TT's Avatar
Yea It has a new one
Stock
Old 05-17-2009, 10:31 AM   #5
projectRDM
projectRDM's Avatar
There is no starter relay inside the car on S14s. The relay is called the clutch interlock, it's under the hood. Is the clutch switch broken or damaged?
FORMERLY R240NA
Old 05-18-2009, 07:09 PM   #6
Z33TT
Z33TT's Avatar
I don't think its damage? Ill go check the clutch relay now to see if it clicks where can i buy a new switch the car started fine 4 years ago before i pulled the motor out. can relays just go bad with out any use?
Stock
