![]() Join Date: Jan 2008
E-Brake light wont go out.
ok so the brake light won't go out on the dash of my 1990 hatch. fluid is to the top and the light goes on and off as i apply the ebrake when the car is not running. but as soon as i start the car the light goes on. battery light also lights up dim. turbo timer reads 13.7v constantly
z32 front calipers, booster and BMC some ideas? |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
on your ebrake hand theres a switch towards the end, remove your center console to get a better point of view. The switch is towards the bottom of the ebrake and when you put the ebrake down it causes the switch to deactivate turning off the light and when you pull the ebrake up it causes the switch to activate turning on the light.
#7 | |
BMC is full.... also as stated above.
damn even if my turbo timer is reading 13.7v??? |
Yeah. my SAFC II was reading normal voltage too. My alternator belt was loose and wasnt charging that well. Once I tightened the belt everything was good again. See if your belt is tight first.
Guest
Posts: n/a
alternator has nothing to do with the brake warning light circuit.
alternator charge light has its own circuit. the brake light works with ether the ebrake switch OR the bmc reservoir level switch. |
The brake and battery light combo is a code nissan uses for telling you battery isnt charging correctly. ITs been covered.
![]() Join Date: Jan 2007
Is there any update on this?
My brake light comes on randomly while I'm driving then goes out. My BMC's full, and my alternator/battery are only a month or two old. |
![]() Join Date: Apr 2005
![]() Feedback Score: 8 reviews
mine is on also. i tried quickly to address it but havent given it much thought until i finish my q45 calliper upgrade.
but what i did notice is.... if i pull up the ebrake the brake light gets brighter, and put it down it gets dimmer but still on. if i unplug the sensor on the bmc the light goes out, and if i use the ebrake, it lights on and off normally. the float isnt stuck and i drained/flushed out the bmc and it was still on. when i do my brake work (Q45 calipers/pads/rotors and ss lines up front, rebuilt s13 calipers in the R w ss lines) i will be doing a full flush and then going from there to address the light. if anyone knows what could be up with mine id appreciate some suggestions |
#14 | |
Guest
Posts: n/a
Those circuits dont even go into the ECU. The alternator (battery charge) light signal comes straight from the alternator, the low brake fluid/ebrake signal goes directly to the hand brake and the BMC. What else, Chun Li throws her bracelets too right? |
#17 |
you have a weak ass connection to your alternator.
you sure you have a plastic or other non metal washer separating the positive source to the alternator? do you have a buzzing noise coming from the fuse panel near your left leg? |
#18 |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
Mike, it's actually true. Search the subject, it's been talked about and confirmed. Hell, I even experienced it when I first bought my S13. Had an incredibly worn belt and once the car was on both the brake light and the battery light would come on simultaneously. Changed the alternator belt and all was perfect in the world.
- Jimmy Wanted: TBD For Sale: TBD |
#19 |
What else could cause this brake light + Battery light Combo?
I had it on my alternator when it was dying (<12.5). I replaced the alternator and it was fine (~13.3v)- and it worked for a while. I left the car out in a hard rain and now I'm getting high overvoltage (15v, that sometimes drops to 13v) and I get both lights. It is overcharging- outside of the alternator what could do this...i.e. where else is there voltage regulation? |
#20 | |
Guest
Posts: n/a
i took apart and traced each and every wire, and i can specifically tell you that the brake light circuit is completely separate from the alternator charge circuit, and none of them go through an ecu or anthing advanced enough to throw a combo code. there is only ONE person on this forum that i would even remotely consider listening to when it comes to wiring, and that would be russ. he is the only one who truly knows the car as inside and out as i do when it comes to wiring and such. so no, there is no combo code. |
#21 | |
#23 | |
Trader Rating: (54)
91-94 FSM EL-46 Last portion of it you see the connection, bulb check relay.
#24 | |
It took several months for my alternator to finally die. After my alt. was changed out, the lights turned off. |
#26 | |
i had the same problem, i had a loose alternator connection and the posi terminal was grounding out as well. get a plastic washer, clean the alternator connections. |
#28 |
Oh wow, I guess that explains why my light stayed on all the time. I had a leak in one of my calipers and constantly had to replace the brake fluid before finally replacing the caliper itself. I thought my ebrake sensor was faulty. ![]()
cardomain.com/ride/3113705 |
#29 | ||
plastic washer? where? positive source on the alt? |
