Old 05-17-2006, 04:42 AM   #1
daredevildoug
daredevildoug's Avatar
daredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-known
z32 pistons in a s13 blacktop!?
i plan on rebuilding my blacktop motor. what are my options considering i do not have much to spend on pistons/rods. from what motor(SE-R, 300zx. etc) can parts be used? the help is greatly appreciated. thanks
-de
ps. yes i searched!
daredevildoug is offline   Reply With Quote
Old 05-17-2006, 05:30 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
I would reckon that any SR20DE pistons would work.
I suppose if the Z32 pistons are the right bore diameter, height, have the wristpin holes in the same spots, and roughly the same ring lands, you could use those too.
edit- 2 minutes making love to Google, and it gave birth to this: http://www.optionimports.com/oemnisrpikit.html
Originally Posted by PHLIP
Old 05-17-2006, 07:23 AM   #3
daredevildoug
nice find... thanks aye. anyone with more info on these z32 pistons? thanks
Old 05-29-2009, 09:45 PM   #4
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
300zx turbo pistons are 87mm bore and should yield ~9:1 CR in the SR. you will have to overbore your engine, they are relatively cheap and are made the same as stock sr pistons. you will have to grind your rod ends for the piston to have enough side to side clearance or mill out a little on both sides of the underside of the piston where the wrist pin goes through.
timtiminy is offline   Reply With Quote
Old 05-29-2009, 09:57 PM   #5
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
just use stock sr pistons.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-30-2009, 03:25 AM   #6
Solidus311
Solidus311's Avatar
Solidus311 is making a name for him/her selfSolidus311 is making a name for him/her self
Wow this thread is old.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 05-30-2009, 07:00 AM   #7
Ka24Power
Ka24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud of
haha "close to stock compression"
do not want.
Ka24Power is offline   Reply With Quote
Old 05-30-2009, 08:27 AM   #8
BlazedGlory
BlazedGlory will become famous soon enoughBlazedGlory will become famous soon enoughBlazedGlory will become famous soon enough
Originally Posted by daredevildoug View Post
can parts be used?
Why would you use used parts when rebuilding an engine? There are already used parts in the engine you are rebuilding...
BlazedGlory is offline   Reply With Quote
Old 03-04-2011, 08:27 PM   #9
sr20dmExT
sr20dmExT is an unknown quantity at this point
Have you done this man??? cuz im trying to go the same way!!! and i need info
sr20dmExT is offline   Reply With Quote
Old 03-05-2011, 07:58 AM   #10
nismoman
nismoman is an unknown quantity at this point
this thread is old as hell!! and oem sr pistons are only like $50 each.......
nismoman is offline   Reply With Quote
