Old 05-29-2009, 08:17 PM   #1
mikemadison_09
mikemadison_09's Avatar
mikemadison_09 is an unknown quantity at this point
ka24det w/sr elbow.. what o2 sensor?
i got a ka24det set up with a sr t25 and the stock t25 elbow, problem is how do i use an o2 sensor in that elbow?
mikemadison_09 is offline   Reply With Quote
Old 05-29-2009, 09:26 PM   #2
S14DB
AFC #1
S14DB's Avatar
Doesn't it have an O2 sensor bung in it?
Old 05-29-2009, 10:02 PM   #3
Om1kron
Om1kron's Avatar
there are two different types of 02 senors, a skinny 02 sensor and a fat 02 sensor. The FAT 02 sensor's on your ka24de will not fit in that elbow you will need the skinny 02 sensor.
Wayne Edwards
https://om1kron.blogspot.com
Old 05-29-2009, 11:08 PM   #4
S14klares
S14klares is an unknown quantity at this point
the skinny O2 bung can also be removed i believe its an 1" wrench or something like that and the remaining hole is i believe the proper size for the big O2. or dont run any o2 sensor b/c its not gonna compensate on the ka ecu for any of that jazz.. you should be running an afc / wideband at the very least. if you remove the o2 you have less of a chance of the ecu pulling/adding fuel and you control everyhting.
S14klares is offline   Reply With Quote
Old 05-30-2009, 12:27 AM   #5
S14DB
AFC #1
S14DB's Avatar
Really? My fattie screwed right in.
Old 05-30-2009, 03:45 AM   #6
JaMeSoN
JaMeSoN is an unknown quantity at this point
so did mine. hmmm
JaMeSoN is offline   Reply With Quote
Old 05-31-2009, 03:49 PM   #7
projectRDM
projectRDM's Avatar
Incorrect. Either sensor fits the same hole, the sensor body is smaller but that's it. The rear O2 on '95-'96 models is smaller, but it's not used anyway.
To the OP - you use the sensor that came on your car. Not that hard to figure out.
FORMERLY R240NA
Old 06-01-2009, 12:17 PM   #8
mikemadison_09
the sensor that is for my car dosent fit the holes, either a bit too big and then the reducer for the skinny is well wayy too skinny for the stock o2 sensor.. and i have a tuned ecu so i kinda need the o2 sensor
Old 06-01-2009, 12:21 PM   #9
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
There should be a big hex nut that screws into the elbow, and the nut has a smaller hole in the center that the O2 sensor screws into.
Old 06-01-2009, 12:51 PM   #10
TNathe
TNathe is an unknown quantity at this point
The auto-parts stores and exhaust shops have o2 bungs. Go find one then remove the one in the pipe and replace with new one or just take the pipe to an exhaust shop with your O2 sensor and say "here ya go"
TNathe is offline   Reply With Quote
Old 06-01-2009, 08:32 PM   #11
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
just get a aftermarket elbow and you will be set!
SilviaSR20DET is offline   Reply With Quote
Old 06-01-2009, 09:00 PM   #12
eclipse_dsm
eclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond repute
There are 2 types of o2 sensor the 3 wire ( Skinny Type ) on the earlier SR and the 1 wire ( Bigger o2 sensor ) on KA and some SRs. You would obviously need the 1 wire so either get a torch or soak it on WD40 maybe liquid wrench also to remove the skinny bung on the SR elbow and do the same on your stock exhaust manifold and then re use the bung from your stock EX manifold on the SR Elbow. GL!!
eclipse_dsm is offline   Reply With Quote
