Old 06-07-2009, 07:25 PM   #1
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
boiling coolant and temp gauge fluctuating
I recently put in a new aluminum radiator (JVT racing 3 rows radiator) plus taurus fan. I bled it and it seems to not overheat, as per the stock temp gauge. While driving onto the highway the stock temp gauge suddenly drops to the first line and at a constant speed would be between the first and second line of the gauge. When on local roads it would go up to between the 3rd and 4th line, which I would say is normal, but when at a stop, the revs would kind of float at around 1500rpms and at times the idle would rise. I looked at the temp gauge and noticed that if i rev the needle would bounce from the 4th line then to the 2nd line then to 1st line then back up to the 4th line. Then I smelled coolant from time to time and when I finished driving to my destination (total of 20 mins on highway and 5 mins of local driving), i can hear coolant boiling in the reservoir, but the temp gauge shows no overheating. Any idea what is causing this issue?
aziankingz is offline   Reply With Quote
Old 06-07-2009, 07:48 PM   #2
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
throw in an aftermarket temperture gauge and see what's really going on. stock ones aren't very accurate. sounds like a wiring issue. but if coolant is boiling the thats a problem aside from the gauge.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 06-07-2009, 08:00 PM   #3
greddyguy
greddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choices
is this an SR or a KA? a friend of mine had the same problem, no matter how much he bled the system it would boil over.
greddyguy is offline   Reply With Quote
Old 06-07-2009, 08:07 PM   #4
aziankingz
aziankingz's Avatar
Trader Rating: (28)
its a ka24e
Old 06-07-2009, 11:32 PM   #5
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Sounds like there is still air bubbles in the system. Sometimes when the traditional bleeding method is not enough (bleeding from the bleeder screw) I like to turn the heat on and have the radiator cap off. Air bubbles tend to surface.
Old 06-08-2009, 12:04 AM   #6
hegamiz
hegamiz's Avatar
hegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nice
definitely, just got a mishimoto rad on friday, my first time bleeding a coolant system, did a damn good job i guess... i used THIS for reference. and THIS vid.
hegamiz is offline   Reply With Quote
Old 06-08-2009, 12:09 AM   #7
I LUV MY S13
I LUV MY S13's Avatar
i had a similar issue after i bled it..went away within like 4 days..
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 06-08-2009, 03:10 AM   #8
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
i had a similar issue, i ran it with the heater on full blast and my motor still blew up. (stock temp gauge is a POS, dont trust it )
DataXUnknown is offline   Reply With Quote
Old 06-08-2009, 11:31 AM   #9
aziankingz
aziankingz's Avatar
Trader Rating: (28)
the way i bled it, i never used the bleeder screw.. just filled up, turned heater on, rad cap off, let car run, rev it at times to release air, checked lower hose if still cold (to check if thermostat opened - which took about 10-15 mins until lower hose was warm/hot) and waited for the bubbles to stop coming out..
