Old 06-10-2009, 01:23 AM   #1
H4ck3d4l1f3
H4ck3d4l1f3 is an unknown quantity at this point
High RPM Shutter
So first off stock redtop, 10psi, exhaust, frontmount, walbro 255,
When I get on it and my rpm rise to about 4-5k my motor shutters and sounds like its missing. Like it instantly has noo power at all. I replaced my fuel filter. What should i try next?
H4ck3d4l1f3 is offline   Reply With Quote
Old 06-10-2009, 01:57 AM   #2
Mr.s13r
Mr.s13r is an unknown quantity at this point
what kind of boost controller are you using? U might be running lean...that what happen to mine when i try to run 13lbs on stock turbo, then i just dial it down to 12lbs something and didnt happen anymore. But then you only running 10lbs
Mr.s13r is offline   Reply With Quote
Old 06-10-2009, 02:56 AM   #3
H4ck3d4l1f3
its a perrin one.
It happened before when i was at 7psi too though.
Old 06-10-2009, 04:07 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
Bad coilpack, wiring problems, loose MAF wire - there's TONS of reasons for this to happen... sadly, they're really hard to troubleshoot. Search around and make a list of all the things to check - eventually you'll find it.
