Old 07-01-2009, 03:07 AM   #1
superbraut
superbraut is an unknown quantity at this point
deleting
deleting old thread
superbraut is offline   Reply With Quote
Old 07-01-2009, 03:54 AM   #2
GSXRJJordan
GSXRJJordan's Avatar
Most likely it's leaking from your shifter hole (that rubber boot that goes around the shifter is probably busted), and it drips down to those low areas before forming into drops.
Take your shifter trim off, you'll see oil - replace the rubber seal up top, enjoy no more leaks.
Old 07-01-2009, 07:29 AM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
could be leaking from the reverse sensor/switch too. or the 5th gear sensor i believe it's called.
clark is offline   Reply With Quote
Old 07-29-2009, 01:57 AM   #4
superbraut
deleting
deleting old post
Old 07-29-2009, 07:44 AM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
you want to plug you sensors?
we usually just put a small coat of RTV on the threads to prevent leaking.
Old 07-29-2009, 02:29 PM   #6
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
Listen to this man, RTV, Tephlon tape, thread sealent, things like that for sensors and fittings. For ur drain plug make sure the copper washer that goes on is not all bent up usually that can cause leaks after a few removals of the drain plug. Add some of the above and change the washer.
FRoSt415 is offline   Reply With Quote
