Old 07-09-2009, 11:23 PM   #1
S13-KA24DET
S13-KA24DET can only hope to improve
Rad hoses pressurized/hot when car's off, overheating driving uphill/longer drives
new autozone radiator cap 0.9
new waterpump
new nismo thermostat
new coolant & flushed system
properly working clutch fan/radiator fan and a/c fan
properly bleed system
proper ducting (radiator panel both on top/bottom)
last i recall, my compression test numbers were 180 all across
coolant/oil not mixed
car typically overheats when under load, driving uphill for awhile, or longer drives
after the car's turned off for awhile the radiator hoses are swollen/pressurized, and they feel a lot hotter than normal (didn't happen on my other s14)
and my car gets warm/normal operating temps fast
S13-KA24DET is offline   Reply With Quote
Old 07-10-2009, 12:05 AM   #2
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Does the overflow tank work properly?
Did\how did you ensure proper coolant flow in radiator?
Have you done a leak down test?
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 07-10-2009, 02:26 AM   #3
YoungGun
YoungGun's Avatar
try taking out the thermostat.
YoungGun is offline   Reply With Quote
